Question about Linksys Cisco Small Business WAP4410N WirelessN Access Point PoEAdvanced Security (S7271261)
There should be a reset button to the right (the back facing you) of the antennas on the back, press that for 10 seconds to restore back to factory default. You may also go into the the web based control panel of the router and set it back to default.
Posted on Dec 06, 2010
I need software of cisco wap4410n to reset passwords if anyone can help me
Posted on Jun 08, 2012
For that you need to press RESET button for 10 seconds it is in the back side of router. then all settings defaults. Then configure it with below method. Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then configure wan settings and lan settings enable wireless if you want to use wifi Then save settings and restart router Then connect cable from internet service provider to WAN port of router and connect ethenet lan cable from computer to lan port of router. . Let me know if you need further assistance. Thanks for using FixYa.
Connect your router to computer with ethernet cable then you can access it with following default link.http://192.168.1.1 orhttp://192.168.0.1 orhttp://192.168.15.1 orhttp://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it
done all these steps but cant get acsess to router now it is working but without secrity
Reset Cisco WAP4410N router to factory defaults
To reset the Cisco WAP4410N to its default settings, you have to do the following steps:
Turn on router
Press Factory Reset button and hold for at least 15 seconds
Device restarts automatically
Default settings have been restored
The unit will reboot automatically. Once the power light stops blinking, the unit has been reset and is ready to use. Resetting the router does not reset the firmware to an earlier version, but it will change all settings back to factory defaults.
I hope these steps will be helpful!
Mark Wilson
Posted on Feb 12, 2021
how was the name reset and by who??????
if you mean you have to reset your router to the factory default settings
(note all settings will be lost you will need to reconfigure the router)
you will need to reset the device to factory defaults. However, once the device is reset to factory defaults, depending on your router) to reconfigure your router settings or if there is a small hole in the front or back of the router push a hair pin in to reset to factory settings
Reset There are two ways to reset the Router's
factory defaults. Either press and hold the Reset
Button for approximately five seconds, or restore
the defaults from Administration > Factory
Defaults in the Router's web-based utility.
There should be a small hole with a red circle around it on the back of the router next to the power plug hole. Use a pin or straighten paper clip to push the tiny button.
Resetting to Factory Defaults
Hardware reset: Push the reset button on the back of the router for 15 seconds.
do not call 4187 or bad happens,
the correct answer is RTM the owner fails to read the manual, and is infact told there how to push a reset button, marked RESET.
