Question about Haier HVT12ABS Compact Wine Cooler
I need to replace the fan Mod FS120252L as it is ceased. Where can I buy a replacement online?
Posted by don_kelshall on
Order capacitors for Hunter fanscapacitors Where
you can call hunter technical support. the number is-- 1-888-830-1326, they should be able to help! have a good day !
Jun 03, 2011 | Hunter 52" Ceiling Fan With Light And...
My condenser plastic fan blade crack , need a new replacement fan , Where can i buy this part, and what is the part number for this replacement fan. Regards Ld
Hi, You did not mention a make and model number, but here is a tip that should help you...
Here is a tip that wrote about how to buy heating and air conditioning partsonline.
How to find Air Conditioning, Heating and Furnace parts online.
heatman101
May 14, 2011 | Heating & Cooling
Compressor is running but fan is not moving at all. Freezer thawed and frige is not cool. Fan was replaced one time already. fan was making almost a vibrating type of noise before it stopped. Where can we...
That is not that hard to fix and you can easily buy the parts yourselfonline...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
Here is one site that I recommend http://ping.fm/zJDAM
heatman101
May 08, 2011 | Maytag MTB2456G Top Freezer Refrigerator
We have a GE V330 003AD range hood with a broken fan blade. Are there replacement blades?
That is not that hard to fix and you can easily buy the parts yourself online...
heatman101
Mar 26, 2011 | GE JN327 30" Standard Range Hood w/ w/...
Fan motor making loud noise. Where can I get a replacement Fan?
Here is a tip I worte about how to buy parts online... it's easy...
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
heatman101
Aug 10, 2010 | Refrigerators
Hi, I have Samsung mod. SC24ZW6 and sametime the fan motor
Hello
Start by replacing the motor capacitor.If this doesnt work then replace the motor.
Jul 26, 2010 | Samsung Heating & Cooling
I need a replacement bulb for my Minka Aire Artemis ceiling fan. Can I buy this locally (I live in Minneapolis) or will I need to order it online?
remove old bulb & take it to a home improvement store,hardware or electrical supply, to find a matching replacement.
Oct 15, 2009 | Minka Aire F803-TL Artemis? Fan
Replace radiator fan motor? where 2 buy cheap online?
Here is my suggestion if you know someone can rewind a motor ask for his help because it is much cheaper to rewind your old motor rather buying a used one.
I’m happy to assist further over the phone at https://www.6ya.com/expert/ramy_d9e7ebea3891f482
Jun 09, 2009 | 1996 Pontiac Grand Am
Haier HVT12ABS Not cooling noisy motor
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} If you bought it before 2006 you have 1 year parts and labor, and 5 years on the motor ! if you called them and they told you one year, they must not have known the date you bought it!
Try the manufacture!!!!!!!!!!!!!!!
They will have the part
Discount Parts
Major Appliance
& Consumer Electronic Parts.
TOLL FREE 1-(888)-338-3790
8:00AM - 12:00 MIDNIGHT
7- DAYS A WEEK
Please rate me solved before you sign off.
Thank You
Sep 14, 2008 | Haier HVT12ABS Compact Wine Cooler
Fan in oven has ceased working
Hmmm. most ovens that I have seen don't have fans (except Microwave ovens), so I will suggest checking the wiring and removing the fan for inspection (you may find it's motor is burnt out?), and if it's faulty, replace it (should be easy to find a replacement at your local appliance parts store).
Apr 04, 2008 | Kitchen Ranges
Haier HVT12ABS Compact Wine Cooler Logo
500 people viewed this question
Top Haier Refrigerators Experts
Vernon Taylor
John Tripp
John Tripp
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
