Question about Hotpoint First Edition WMA12 Front Load Washer
Hotpoint first edition WMA10 making a bangin noise during wash programme. Cannot find filter in order to clean. [email protected]
Posted by trishisfit20 on
Anonymous
    Master:
  • 414 Answers
I have the same model at work only under the frigidaire branding. The shock mounts for the
drum are made of plastic and can break (especially if the unit is moved without the
shipping screws) If one breaks the unit will make a clunking sound.
Posted on Feb 26, 2011
Have a whirlpool duet front load washer, was making a loud bangining noise during spin and now will not spin, it drained though.
It is so common that the washing machine can make terrible noise in many ways and is a common fault. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that machine is vibrating when it is running then the motor /drum suspension has to be inspected. Since these fittings are located on the underside of the machine it is important that you look for the noise with a good inspection lamp. Manually turn the motor and drum and listen for the noise, if so the motor bearings, the drum agitator shaft and fittings must be checked. Also the suspensions which include the shock absorbers and springs, the body clamps must be checked to be in correct alignment and not changed in position. Tightening of the mounting is also very important. Finally in most cases a drop of OIL or smear of grease on the moving parts cane solve most issues.
Check this link :
http://www.espares.co.uk/advice/washing-machines/a/7/1210/wobbly-washing-machine-or-tumble-dryer.html
For replacement of bearings check for tips on this visual link: http://www.espares.co.uk/advice/washing-machines/a/7/1401/how-to-replace-the-bearings-on-a-washing-mach.html
Jun 11, 2012 | Whirlpool Duet GHW9150P Front Load Washer
Hi. is the front filter on hotpoint wma10 removeable. The machine is not draining properly after cycle but putting it on spin only cycle twice removes most of the water.
Most hotpoint filters are Located under the drum centre ..you need to remove the big sump hose/ clipe off then the filter is inside here . give it a good clean the water test machine for any leaks before using...Good Luck
Mar 19, 2011 | Washing Machines
LIST OF WASHING PROGRAMMES ON FRONT WERE ERASED BY CLEANING. PLEASE LIST PROGRAMME TYPES, NUMBER AND TEMPERATURES. THANKS.
Go to:
WWW.HOTPOINTSERVICE.CO.UK
Follow the links in the left hand side menu, you should be able to download a copy of the user instrctions, which will show you the programmes.
Oct 20, 2010 | Hotpoint Ariston Aquarius WD420 Front Load...
Hotpoint WT540 1400 spin. Flashing Rinse hold and Mini load LED
Had exactly the same last week - Jan 09 - and had to call out Hotpoint engineer - £99.98 all inclusive of parts - it was the main controller board, so thats under guarantee for another 12 months. all working and spinning as should be and only took around 30mins.GS :)
Dec 29, 2008 | Hotpoint Washing Machines
Hotpoint washing machine model WMA10
the filter is on the front bottom left or right. if this helps please rate joe
Nov 21, 2008 | Hotpoint First Edition WMA12 Front Load...
Ginko
Hi, We have just put our Hotpoint few 12 backtogether. If you tell me exactly what you need to know I will take the front panel off and let you know. contact me on [email protected]
Aug 17, 2008 | Hotpoint First Edition FEW12 Front Load...
Faulty Hotpoint WMA76 washing machine
it may be 1) a connection loose at the motor 2) motor brushes are worn out 3) a pcb fault check in that order.
Feb 16, 2008 | Hotpoint First Edition WMA12 Front Load...
Problem with our washer/dryer
sump/filter is blocked instead of flushing on dry cycle is filling as not pumping well. ring hotpoint to reorder pts cheaper then anyone
Jan 06, 2007 | Hotpoint Aquarius WD63 Front Load...
WMA10 abridged programme cycle
is the drum going round at all if not then most likely your carbon brushes which puts power to the motor there is 2 either side of the motor you will need some bent nosed pliers to take them out must have at least 8ml of carbon on them
Sep 26, 2006 | Hotpoint First Edition WMA12 Front Load...
Hotpoint First Edition WMA12 Front Load Washer Logo
Top Hotpoint Washing Machines Experts
gbob59
Lawrence Oravetz
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
