Question edited for a lot more clarity. Your 'Possess F&K DW60FC' does not exist! :>D
Question moved from Televisions category.
Rebooting is not the fix, it won't work until you fix the pumping out.
Fisher and Paykel dishwasher error codes f30
The F30 error code signifies that the flood switch on your machine has been activated. This indicates a problem with water drainage. This could be a one-off issue, or it could be a symptom of something deeper. For example, if the drain hose is bent or blocked, it could cause dishwasher problems like flooding.
The F95 error code appears on Panasonic inverter air conditioners due to the overheating of the outdoor coil. It is basically, protection against the outdoor high-pressure rise. This problem usually occurs due to issues relating to blockages, a dirty condenser coil, cool mode, or low gas.
In the first instance cut off the power to the outside unit for 1 hour. When you turn the power you will hear all sorts of clicks as relays open as close as part of a self test procedure. Wait 10 minutes before powering on.
You have to use the remote in service mode to find the error code. Hold the 'check' button in with a paperclip for about 5 seconds and "--" will be displayed on the remote. Press timer up or down will change the error code displayed. When you hear the main unit start beeping quickly for about 4 seconds, that is your error.
Do you mean F03? that error is known in Panasonic video products. It usually applies to the VCR, which means a mechanical fault; such as loading motor and/or mode switch. The switch itself would be on the main board under the VHS deck, and can be cleaned with special electronic spray cleaner, and electronic lubricant (after the cleaner), but for more reliable results, the mode switch may require replacement, which should be done by a workshop. If this is the only issue you have with your combo unit, it shouldn't cost too much to correct this problem. Either try cleaning the switch yourself (being careful when opening unit), or submit to workshop for quote and professional repair.
I have never heard of F30 as a video/DVD error code before. That error applies to some Panasonic air-conditioners and is a system error.
