Posted on Dec 06, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can I print on two sides with the Artisan810?
Anonymous
Level 3:
  • Epson Master 32,281 Answers
  • Posted on Dec 06, 2010
Anonymous
Epson Master
Level 3:
Answers
32281
Questions
Helped
7905673
Points
102259
If your printer does not have a duplex unit then the printer cannot print double sided pages automatically.
You can print double sided pages but you have to do it one page at a time.
First print Page 1 then place the page back into the paper tray, but turn the page upside down and the print Page 2.
Then print pages 3 & 4 on both sides and repeat for the rest of the document.
I suggest you try a test page first to get the printing right way up so the page reads correctly.
1helpful
After setting up my C6380 for two sided printing it will not do side two.
You are ticking the box for 'Print Both Sides' aren't you?
I find it quicker to print Even sides only,
then reload the paper (same order as it comes out printed Even sides) and tell it print Odd sides only
Try that.
How can I do a 2 sided print
DOUBLE SIDED PRINTING USING A SINGLE SIDED PRINTER
Then print page 3 on one side then page 4 on the other side and repeat for the rest of the document.
I suggest you try a test page first, to get the printing the right way up on both sides of the page so it reads correctly.
1helpful
I have a lexmark x6570 printer it will not print on both sides of the paper anymore it use to print on one side then pull the paper back in as use the other side
Please follow steps below on how to print 2-sided on your printer:
Printing on both sides of the paper (duplexing) automatically:
  1. Press printmastert_76.jpg.
  2. With a document open, click File > Print.
  3. Click Properties, Preferences, Options, or Setup.
  4. Click the Print Layout tab
  5. From the Duplexing area, select Use Printer Settings from the drop-down box.
  6. Make sure the printmastert_77.jpg light is on.
  7. Click OK to close any printer software dialogs that are open.
Printing on both sides of the paper (duplexing) manually:
  1. With a document open, click File > Print.
  2. Click Properties, Preferences, Options or Setup.
  3. Click the Print Layout tab.
  4. From the Duplexing area, select Manual from the drop-down box.
  5. Select the Print manual duplex instructions check box.
  6. Press Start.
  7. The printer prints the odd-numbered pages and the instruction sheet, which describes how to flip and reload the paper.
  8. Following the instruction sheet, flip and reload the paper with the printed side facing away from you.
  9. The printer then prints the even-numbered pages on the reverse sides of the odd-numbered pages, completing the two-sided sheets.
Note:
  • printmastert_78.jpg button is not functional with a Macintosh operating system. You can print two-sided documents with a Macintosh operating system by using the settings in the Two-Sided menu of the Print dialog.
  • Automatic two-sided printing (duplexing) works only with plain paper in letter and A4 sizes. If you want to print two-sided documents on another size or type of paper, use the manual duplexing method.
  • To return to single-sided printing, make sure the printmastert_79.jpg light is not on.
2answers
How can I do double-sided printing with my Canon MP460?
Hi there!You printer does not have an automatic duplex(double-sided printing)so you have to make a manual double-sided printing.When you start to print something , in the widow of the printer click on the preferences and look for the option "Print on both sides" or "Manual double-sided printing".When you start the printing the printer will print page page 1,3,5,7..... on the one side of the paper.After the printer finish you have to take the papers and put them back in the printer with the other side of the paper.Then the printer will start print page2,4,6,8,.....If you need any other help please replay!Tghaky for using Fixya!!
1helpful
Does the Lexmark X9575 print automaticly 2 sided with no manual feed. I have a 15 page document doulbe sided. How do I print this without babysitting the printer. Thank you
Your model supports automatic duplex printing using letter and A4 sizes ONLY. If you want to print two-sided documents on another type or size of paper, use the manual duplexing method.
1) With a document open, click "File" > "Print..."
2) Click "Properties" or "Preferences" or "Options" or "Setup" depending on your system
3) Click the "Advanced" tab
4) From the "2-Sided Printing" area, select the 2-Sided Printing option and then select either the "Sideflip" or "Topflip" option (sideflip is the setting most often used)
5) From the drop-down box, select Automatic.
6) You will see an "Extend dry time" option, which allows extra drying time between sides when you are printing on both sides of the paper. The Automatic 2-Sided Printing option affords enough time for the ink to dry on supported paper types in average air humidity. Under conditions of high humidity, or if the normal drying time does not allow the ink to dry completely, you should select Extend dry time.
7) Click <OK> to close any printer software dialogs that are open. This will take you back to the General Print screen.
8) Click "Print"
Note: To return to single-sided printing, return to the Advanced tab. From the 2-Sided Printing area, clear the 2-Sided Printing check box.
3helpful
2answers
Do pixma Mp610 support duplex printing
The MP610 does support duplex printing.
Duplex Printing
The duplex printing function allows you to print data on both sides of a sheet of paper.
The procedure for performing duplex printing is as follows:
Performing automatic duplex printing
You can perform the duplex printing without having to turn over the paper.
1. Open the printer driver setup window, check the Duplex Printing check box, and confirm that Automatic is checked.
2. Select Normal-size Printing (or Fit-to-Page Printing, Scaled Printing or Page Layout Printing) from the Page Layout list.
3. When printing a document that has small margins, click Print Area Setup... and set the print area.
When you perform duplex printing, the print area of the document becomes slightly narrower than usual and the document may not fit on one page.
sub.gifTo print without reducing the page:
Select Use normal-size printing.
sub.gifTo reduce the page slightly during printing:
Select Use reduced printing.
4. Specify Staple Side.
The printer analyzes the Orientation and Page Layout settings, and automatically selects the best staple position. Check the Staple Side setting. If you want to change the setting, select another value from the list.
5. If necessary, click Specify Margin... and set the Margin width.
6. Click OK.
Duplex printing will be started.
Performing duplex printing manually
You can perform the duplex printing manually.
1. Check the Duplex Printing check box and uncheck the Automatic check box on the Page Setup tab.
3. Specify Staple Side.
4. If necessary, click Specify Margin... and set the Margin width.
5. Click OK.
sub.gifIf a media type other than Photo Paper Plus Double Sided is selected for Media Type on the Main tab:
When you execute print, the document will be printed on one side of a sheet of paper. When printing is complete, reload paper according to the displayed message and then click OK. The document will be printed on the opposite side.
sub.gifIf Photo Paper Plus Double Sided is selected for Media Type on the Main tab:
When you execute print, the document will be printed front and back alternately for one sheet at a time. Load the paper according to the displayed messages.
caution.gif Note sub.gifDuplex Printing is unavailable when:
- A media type other than Plain Paper, Photo Paper Plus Double Sided or Hagaki is selected from the Media Type list.
- Poster Printing is selected from the Page Layout list.
sub.gifWhen Booklet Printing is selected from the Page Layout list, Duplex Printing and Staple Side appear grayed out and are unavailable.
sub.gifAfter printing the front page, there is an ink drying wait time before starting to print the back page (Operation stops temporarily). Do not touch the paper during the time. You can change the Ink Drying Wait Time at Custom Settings on the Maintenance tab of the printer driver.
sub.gifWhen you perform the automatic duplex printing for Hagaki, print an address first and then print your message.
refer.gif Tip sub.gifIf you select Photo Paper Plus Double Sided for Media Type on the Main tab, the Duplex Printing check box on the Page Setup tab is not checked automatically. To perform duplex printing, check the Duplex Printing check box.
sub.gifIf the Media Type dialog box appears when performing borderless printing during duplex printing, select Plain Paper or Photo Paper Plus Double Sided.
sub.gifWhen performing the automatic duplex printing, do not use any plain paper smaller than A5. Also, do not select any type of paper other than Plain Paper, Photo Paper Plus Double Sided or Hagaki at Media Type.
sub.gifPhoto Paper Plus Double Sided is highly recommended for printing photographs on both sides of a page.
sub.gifIf the back side of the paper becomes smudged during duplex printing, perform Bottom Plate Cleaning in the Maintenance tab.
2helpful
2answers
Machine will not print double-sided documents
Try resetting the NVRAM from the diagnostics screen.
Printing booklets in Word 2007!!
Under file > print set up select two sided it will print bot the sided
1helpful
Top Epson Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
NH TECH
Level 1 Expert
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
