Nintendo Wii Fit for Wii Logo
Posted on Dec 06, 2010
My Wii fit weighs me at about 20lbs less than all other scales (maybe I shouldn't complain). How do I resist it so it will be more accurate?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Dec 12, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
140
Points
Are you doing it on carpet? Mine does the same and I put the board on a hard suface and it's accurate.
1helpful
Why does salter scales round up when measuring grams
Because you have a scale that weighs in whole grams not parts of a gram. You need a more accurate scale like these which weigh to 1/00th of a gram (0.01 grams).
https://www.walmart.ca/en/ip/fashionhome-500g-0-01g-Weigh-Gram-Scale-Digital-Jewelry-Pocket-Scale-Backlit-Display-Tare-Function-Food-Weighing-Tool/531FGVNPN850
My etekcity scale is showing a C shape on the screen after weighing something - what does that mean?
A "C" will appear during the first weighing, this is a self-calibrating feature on some scales. It means the scale is re-calibrating to zero. Please re-weigh for accurate reading. Scale will also re-calibrate after every battery replacement.
1helpful
For seca 763 having problem with the display. All led segment was displayed and weight is varying.Kindly help.
Try weighing an inanimate object, is the weight stable? Maybe you're stabalizing yourself by holding on to something? That will throw it off. all weight must be on the base and not moving to get an accurate reading. If it's still unstable it need new weight sensors and calibration. Probably not a DIY.
My WW78 scale keeps giving an ERR message when I stand on it.
Usually I change the weight by weighing one foot and then weighing again with both. And then I keep repeating that until my results are consistent. Then that result seems to be accurate
My weight is not accurate. I weigh 260+ and the scale reads 245 to 249 and is inconsistant. I just replaced batteries (CR2032)for the second time
Very few electronic scales are accurate as they are a function of a resistance measured against a voltage. They may be accurate when you buy them, but over time the electronic components decay and read differently as the components are cheap 10% type resistors and capacitors and cannot hold their specific values over time.
If you want accuracy, you will have to get a balance type scale that can be calibrated on site.
I need WeighMax Pozo 35 Instructions
This scale perfectly fits my needs. It takes up very little space on a side table, and has held up great weighing the 5-10 packages I mail per week. I have found it to be perfectly accurate and would recommend it to someone else planning on using a scale with the same frequency as me!
Wii Fit Weighing Me Wrongly
You should probably put it on a board but if that doesn't work, you could try putting something weighing 12 pounds on the board or in your pockets or whatever.
1helpful
2answers
Wii fit weighin too light!
I would suggest that you ensure that the board is calibrated properly and that you don't step on it until directed to do so. I'm sure you're already doing this, because it won't let you go on without doing so.
The other solution I would offer is to change the batteries in the unit, and ensure that you are setting the Balance Board on a smooth, sturdy, and flat surface. If you are on shag carpet, it will not function properly. If you have average carpet, try using the little adapters that attach to the feet.
Remember that for the purposes of this program, the exact weight isn't what is most important, but relative weight. Any time you are tracking weight loss, be sure to mark your progress using the same scale. If you chart the Wii vs traditional scales, you should notice that the decrease is the same, regardless of what your starting point may happen to be.
Scale not accurate
This link allows you to trouble shoot directly with the company... I hope this helps. http://www.taylorusa.com/advantage/root/contact.html
Top Nintendo Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
Aron
Sean Wright
Sean Wright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
