Question about Weiser Lock POWERBOLT ELEC DEADBOLT
Replacing powerboat, new one not working. Bolt not traveling far enough, too weak to unlock.
Posted by lindamjennin on
MGush
    New Friend:
Open door so you will have access to both sides (need 2 hands at same time) - hold down 'lock' button while with other hand, remove battery pack for 15 seconds. Reinsert battery pack & then release the 'lock' button. Ensure new batteries, otherwise can remove batteries from holder for 30 sec then reinsert. s/b smooth operating deadbolt latch when door open - may also have to adjust latch plate slightly on doorway if required.
Posted on Feb 15, 2016
steve_hyde
    Problem Solver:
  • 17 Answers
You should replace your batteries as the motor that moved the deadbolt does not have enough power to move it with weak batteries. If that fails make sure the deadbolt moves freely when the lock is removed as the mis-aligned mounting will cause excessive force be exerted to move the deadbolt. See http://www.weiserlock.com/Support/Faq/50160000000HhbGAAS.aspx
Posted on Dec 26, 2010
Why can't my powerboat find it's way home and when I manually attach it, it will leave and wander around
Is your powerboat sentient? Most vehicles cant find their way home yet. Unless powerboat is a name of something else.
Feb 02, 2018 | Cars & Trucks
When I try to lock passan how do I adjust power door so as to lock &unlock door
May need to remove door panel and lube all moving parts. Possible bad solenoid.
Jul 15, 2015 | 2000 Ford Windstar
Chain tight against stop bolt and will not close
Take the stop bolt out and run the garage door down.
Adjust your up travel limit so it spent open up so far.
Replace the stop bolt and nut.
Aug 25, 2014 | Sears Craftsman LiftMaster Chamberlain...
Replacing the forward fixed track bar in the rear suspension on my 2000 pontiac grand prix gt and i cant pull the upper bolt out far enough to remove the track bar because the bolt hits the gas tank. If...
possibly the bolt was incorrectly fitted at some stage so you may have to drop the tank a bit to get the bolt out . If so place a trolley jack under the tank. use a bit of flat wood to prevent damage to the tank. undo the tank straps and lower the tank just enough the get the bolt out.
Mar 09, 2014 | Cars & Trucks
When is the next United States Powerboat Show?
Unfortunately, you just missed this year's show - it was held on October 13th. Check out the following link to find info about this year's show and to learn more about next year's show when in becomes available:
http://www.usboat.com/us-powerboat-show/special-events
Oct 16, 2013 | Boating
How much does a Nordic powerboat cost?
My friend just bought one and is very happy with it.
New Nordic powerboats usually cost around 150-250k.
A used one can go for 60-90k.
Have a new quickset on entry door from garage. works fine for a couple of days then will not unlock. key will turn and can manually move latch from inside, but lock will not release....any ideas? greg
There is a tubular "Lazy cam" or tailpiece that passes from the cylinder on the outside operated with a key through the bolt and into the thumb turn on the inside. There is as "E" clip that holds the tubular Cylinder bar or "tailpiece" in place. Fixing it to the back of the keyed cylinder. The center portion of the clip ( that differentiates it from a "c" clip ) passes through a slot in the Cylinder bar to limit its "free rotation" this allows the tailpiece to turn freely enough for the thumb turn to operate the bolt from the inside without binding against the keyed cylinder on the outside, from the outside when you rotate the key far enough in either direction the clip comes to the end of the slot, catches and rotates the bar to operate the bolt. your problem is a broken clip. It is very common, and has been a vulnerability with this design for decades. The cause is usually tension on the bolt during operation with the key ( bolt dragging or rubbing against the strike on the frame) . You can replace the clip and relocate the strike plates on the frame to avoid this again or purchase something a little better than Kwikset.
Apr 21, 2013 | Kwikset Locks & Locksmithing
What is the difference between a powerboat and a jet ski?
5_22_2013_9_45_08_pm.jpgvs.5_22_2013_9_44_20_pm.jpgA powerboat is the type of boat you traditionally think of as a motorboat or speedboat. Imagine a water skier behind it. A jet ski is a personal watercraft for 1-4 people. The passangers sit on top of a jet ski with their legs on either side.
Jan 17, 2013 | Boating
Sears Craftsman 3/4
Open up the caseand look at the travel assy. Sometimes the limit (up or down) do fall off the assy. Just snap it back on.
Jan 06, 2009 | Sears Craftsman LiftMaster Chamberlain...
Weiser Lock POWERBOLT ELEC DEADBOLT Logo
376 people viewed this question
Top Weiser Lock Locks & Locksmithing Experts
john h
ray gallant
Are you a Weiser Lock Lock and Locksmithing Expert? Answer questions, earn points and help others
