Nintendo Wii Console Logo
Posted on Dec 06, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I am trying to insert a disk into my wii but it wont go all the way inside
Anonymous
Level 1:
New Friend:
  • Contributor 31 Answers
  • Posted on Dec 06, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
31
Questions
0
Helped
2814
Points
44
Check whether u insert your disk correctly..................u can easily fix this problem by using repair guide...my friend also faced similar problem..he fix it by using repair guide..........thanks....all the best
click here to download
Anonymous
Level 2:
New Friend:
  • Expert 166 Answers
Anonymous
Expert
Level 2:
New Friend:
Answers
166
Questions
0
Helped
15745
Points
313
Take your wii console to shop and repair it,,,,,,,,,,,,,,,,,,,
if no shops near you , dont worry there is a way to repair it by your own...................
download repair guide and follow the steps and fix your problem...
click here to get repair guide..........................
3 Related Answers
Anonymous
  • 3 Answers
  • Posted on Feb 02, 2009
SOURCE: I think that my little brother put something inside wii console
The mechanism that accepts disk is faulty probably due to something being forced into slot. Have fixed many problems the same as this. If you need me to have a look let me know [email protected]. NO FIX, NO FEE returned free of charge
nelsontimmy
Tim Nelson
  • 83 Answers
  • Posted on Mar 15, 2009
SOURCE: wii will not read disks
sounds like your wii's drive is bad. contact nintendo if your still in warranty
Anonymous
  • 54 Answers
  • Posted on Feb 17, 2011
SOURCE: wii disk wont spin any disks
Hi there jus4
What to do when your Wii Has problems with reading disks and you have tried cleaning the disk.
This does not mean your Disk Drive needs replacing more often than not it just needs the laser to be readjusted.
Option 1
You can send this off to Nintendo if your still in warranty because it is included in there free fixes so they will do the collecting for you, fix it and return the Wii to you, all for free, but it will take 4-6 weeks.
Option 2
If you are out of warranty its the same process as above but its $150 in cost
Option 3
now a new Disk drive would cost around $75 for a compatible one and you may need some one to fit it at a cost as well.
Option 4
What I recommend is a Wii Repair Guide that will show you the simple steps yourself, you will be up and running again in less than an hour and the cost is far less than option 2 & 3
Good Luck
Chris Foley
Feel Free to leave me a comment if you need further assistance.
1helpful
I have a Nintendo Wii and every time when i put in Wii sports resort it always says unable to read disk check Wii operation manual guide for help troubleshooting. but i lost my Wii operation manual guide...
Your disk may be scratched or dirty, make sure it is inserted the correct way. try inserting another wii game and see if it can read that.
You can try to clean your disk using this guide, but if its scratched then it wont help.
1helpful
When i insert a disk it wont work
does this include all disks? or certain discs? make sure the discs are clean. try to buy an optical cleaning disc to clean the internal disk drive inside the wii.
1helpful
When U turn the wii on & put N a disk, it errors & it wont work
try to purchase an optical cleaning disc and let it clean your drive inside your wii. also make sure your discs are clean.
I put in a disk and it does not read the disk. The blue light goes out immediately after inserting then nothing
Sounds like the DVD drive inside of your Wii may have failed.
This drive should fix any reading issues you are having with your games, or issues inserting your games or ejecting them (or lack thereof). This is the entire DVD drive assembly mechanism replacement for your Wii including a new laser. If your discs are not ejecting, or you cannot insert a disc -- or you can insert a disc but it will not load, this is what you need to get your Wii going again!
http://store.richspsxparts.com/wiiredvddr.html
Says disc not being read
Is you WII Softmodded/Hardmodded by any chance? That could be part of the problem. Are you inserting compatible disks? Are you inserting the disk shiny side inwards (towards the inside of the machine/buttons)
Have a look at http://www.nintendo.com/consumer/systems/wii/en_na/ts/gameDiscs.jsp#wont_play
1helpful
Wii unable to accept/eject disc making buzzing sound
  • When the disks were put in/taken out the little plastic clips in side the wii may have broken off. Might be stuck near the motor. Gently shake while rotating the the wii with all the cords off with no game inside. listen for anything loose. If your lucky the piece will go to another part of the wii. Best thing is to find someone to take it apart to check.
Wii will not read disks
1helpful
Wii wont play disk
When the Wii takes in a disk two metal fingers rise up to block the opening. These probably got bent when your two year old tried inserting the second disk. If they are bent they will rub the edge of the disk and prevent it from rotating. If a smaller game cube disk will work then bent fingers is the most likely problem. They can be bent back out.
2answers
Gamecube games lodged in Wii
Only one disk can fit inside a Nintendo wii so possibly your game cube game got stolen
Top Nintendo Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
Aron
Sean Wright
Sean Wright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
