Question about Vivitar ViviCam X327 Digital Camera
Every time I take a picture outside, they turn out with a blue tint!
Posted by lisadsiemens on
Anonymous
    Genius:
  • 1,177 Answers
Artificial light is a different colour than daylight. Our eyes compensate, so we don't notice it much. Digital cameras can compensate too, but whether they do or not depends on the settings. The setting you want to investigate is colour balance. If this is set to daylight, it will give an orange cast to pictures taken in tungsten lighting, and a greenish cast to pictures taken in fluorescent light. If it is set to artificial light, pictures taken in daylight will have a bluish cast. The best setting for most people is Auto. That will let your camera decide, and usually it will get it about right.
Posted on Dec 06, 2010
I need to get rid of the blue tint on all my pictures
Have you checked your camera's white balance setting ? Try setting it to 'Auto' and see if that helps. If not, then there may be a fault in the camera's electronics, which would indicate repair or replacement.
May 30, 2016 | Cameras
BLUE TINT ON MY SCREEN
Philips tv's have always had this problem. Between the picture tube and focus lens there is a layer of coolant fluid. The coolant fluid, over time, will break down and turn a brownish cloudy color and it usually starts with the blue. Something to do with the color frequency. Have a good repair shop check it out and if the fluid is the problem have them change all the fluid in all 3 picture tubes (there is a red, green and blue tube). Don't feel bad, like I said all the philips projo's had this problem. Thanks
Oct 29, 2009 | Televison & Video
BLUE TINT ON SCREEN ALL THE TIME, COLOR ADJUSTMENTS FINE
Sounds like a bad blue CRT (picture tube) ITs expensive and difficult to replace. CAll a Sony service center for an estimate. but expect to spend $500-700 to replace it.
michtech
Feb 18, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Green tint and psychedelic color swirls in picture
I have a good but with green tint on a polaroid tv model number 64SX505Y-DC02
Dec 28, 2008 | Polaroid FLM-3232 Television
Poor quality pictures
Check your picture settings, the wrong setting for the time of day or object can definetly throw off the appearance of your pictures. Plus, you may have accidentally set it to "warm" instead of auto or black and white, etc. Warm pictures have a reddish tint to them just as the cool have a blue tint. Also I have found the "night setting" only takes really good pictures if you are close to the subject otherwise it is pretty dark!
Aug 16, 2008 | Kodak EasyShare CX7330 Digital Camera
Picture fads to Blue after a 30 minutes the picture comes back with a blue tint.
yeah you need a tech to adjust the bias of the picture tube if you are lucky that fix it other wise the blue picture tube is bad
Apr 29, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Horizontal Lines and Blue Tint on my Sony KDP 57XBR2
ok,your porblem is very simple,reheat or resolder the main board your tv.
Oct 22, 2007 | Sony Grand WEGA KDP-57XBR2 57" Rear...
Sony KP-51WS500
does it have blue video image?
Sep 29, 2007 | Sony KP-51WS500 51" Rear Projection...
Blue Tint
Most likely cause would be a loose solder connection that expands as the set warms up until it no longer makes a connection. You may get the blue to come and go by hitting the side of the cabinet after the set is warmed up awhile. (don't hurt your hand doing this, and don't keep doing it to "fix" the set. The connection will have to be located and repaired). Otherwise, there could be a component going bad, including the blue picture tube.
Nov 21, 2006 | Samsung HCN473W 47" Rear Projection...
Vivitar ViviCam X327 Digital Camera Logo
Top Vivitar Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
Lee Hodgson
Lee Hodgson
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
