Yahoo Mail Logo
Posted on Dec 06, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I set up an e-mail account? Thanks, Arlene
Anonymous
Level 3:
Guru:
  • Master 832 Answers
  • Posted on Dec 06, 2010
Anonymous
Master
Level 3:
Guru:
Answers
832
Questions
0
Helped
184520
Points
2366
Hello Arlene;
Just visit this link, http://www.yahoo.com
3answers
I can't receive my mail.
What type of server that your e-mail account works with?
If you are using POP3 or IMAP account, please configure Incoming mail server.
You should try the given below solution to resolve the occurred issue:
Sol 1:
Open "Microsoft Outlook" >> Click on "File" tab >> "Account Settings" >> "Account Settings", locate your account and click on change.... then click on "More Settings" to configure Incoming mail server.
If you are using Microsoft Exchange account, check if you use cached exchange mode. If not, enable it. Click on "File" tab >> "Account Settings" >> "Account Settings" locate your exchange account and click on "change...."
Under server settings, check Use cached exchange mode.
You can check another setting to help resolve being able to send but not receive e-mail messages.
You can set up Microsoft Outlook to check for new e-mail messages at intervals of one minute to 1,440 minutes (one day).
On the "Send/Receive" menu, point to "Send/Receive Groups", and then click on "Define Send/Receive Groups".
Select the group that contains the e-mail account that you want to regularly check for messages.
Under Setting for group "group name", select the Schedule an automatic send/receive every x minutes check box.
Enter a number from 1 to 1440 in the minute's box.
Click on "Close" button. On the Send/Receive menu, click Send/Receive All folders.
Sol 2:
Open "Microsoft Outlook" >> Click on "File" tab >> "Account Settings" >> "Account Settings" >> Click on "Change Folder" button >> Change from whatever it was to: Outlook Data File - Inbox
Close the dialog, click on send/receive or press F9 button and see if it works.
Thanks & Regards
Captain Ashish
Arlene.Lamparter
Arlene, I can describe a problem that is common, called spoofing. When someone receives an email thought to be from you, we immediately think that our email has been hacked. You may be the victim of a spoof, where a hacker uses your address book to send out viruses or just annoyances to everyone in your address book. Spammers use this technique to hide their identity (like putting someone else's return address on an envelope). Some are harmless, others harmful, all are invasive. You may be able to get rid of the problem by running a malware detection program (I use malwarebytes, which is free to private users, and I run it at least once per month.), but you should also change your password in your instant messenger/email/facebook account, etc. In fact, it is a good idea to change your passwords regularly to keep the unfriendly out. I hope this helps.
Switch
go to google account settings, on this page (dashboard) you can see and change your default (standard or normal) settings, you can change your email account to primary from there
I need help to set up micrsoft outlook. My internet provider is Rogers please assist. thanks
Launch Microsoft Office Outlook 2007.
Click Tools on the top menu and click Account Settings.
Select the E-mail tab, and then click New.
Check Manually configure server settings or additional server types, and then click Next.
Select Internet E-mail and click Next.
nter the Rogers email settings as follows: Your Name Your email address Account type : POP3 Incoming Mail server : pop.broadband.rogers.com Outgoing Mail server : smtp.broadband.rogers.com User Name : your full Rogers email address (including @rogers.com) Password : Your email password When you are done entering the settings as shown above, click Next.
Click on Outgoing Server tab and check "My outgoing server (SMTP) requires authentication".
Click on the Advanced tab and change the port number of Outgoing server (SMTP) to 587, then click OK to return to the Add new E-mail Account window. On the Add new E-mail Account window click Next.
Click Finish.
4helpful
Cannot send e-mail through my I-phone from my Hotmail account. Getting the error message: "Cannot Send Mail--The connection to the outgoing server ?stmp.live.com failed. Additional Outgoing Mail servers...
Try this
Go settings, mail contacts calenders and then select the account you want to configure at the top. Then scroll down to outgoing mail server and tap SMTP. Tap primary server turn on and enter hostname = smtp.live.com, user name is your email address, password as per your account, ssl to ON, port 587.
Hope this helps and if so please vote.
Thanks
Jim
Hi, I have a problem regarding the connection between Yahoo! and my Outlook. I will be able to receive my e-mails in Outlook but I will not be able to send any e-mails directly from Outlook. Because I have...
you pointed outed the "e-mail' account settings so make sure of fine submissions such as POP / SMTP & other settings with respect to you server settings under e-mail tab which is accessbile through tool menu and account settings link.. have fine
I cannot find the booklet on the rheem's hot water heater to adjust the water temp. Model # 42VP50Fu. Thanks We just moved into this home and would like to lower the temperature. Bill and Arlene
Hi,Bill and Arlene,in front of the unit there is a square box,on that is a dial,turn it to the right for more and left for less. please rate my answer.
4answers
0send/receive showing 0 of 52 task completed?
hi!!!!!
may be there is a problem in your ISP
so try to resend it
or try to zip your jpegs file and then sen it to email!!!
E-mail
contact ur service provider for setting up an e-mail account.
in the message menu u'll have an option called e.mail. click it and follow the procedures.
Top Yahoo Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Sean Wright
Sean Wright
ADMIN Andrew
ADMIN Andrew
Are you a Yahoo Computer and Internet Expert? Answer questions, earn points and help others
