The cooling system is pressreized a little over 14 lbs when its hot the leak is likely the sorce of the problem
Do you have some other type of question about this system on the range rover ?
Canyou see where the leak is coming from. If its the radaitor witch is likely the cause then you may be able to have it repaired sometimes they can be fixed however it will have to come out of the vehicle.Some however can't be repaired there plastic and glued to the cooling fins you would be best off to replace the radiator. But if its a hose or gasket leak that can be repaired relitively easy because you must know parts for landrovers usely don't come cheap well good luck
People need to be a little bit more percise with their questions.Yes I had a hot running boat once with a slow leak ,can you guess what happened ? It Sank,so fix the leak . And which ocured first the running hot or the leak? let me know and I will try to help you out.
well it started running hot and leaking at the same time.
