SOURCE: image convergence problem
Are you able to have any control over the red and blue convergence in all 4 directions? If not you need to replace the convergence ICs they cost about 10.00 each you will need two of them. A classic sign of bad Convergence ICs is a distorted picture at the top and bottom with the convergence out of alignment on at least 1 color. Let me know if you need anything further.
SOURCE: Double image - colors out of sync, concave image
bad converage ic's, check reisters around them and fuses for -&+VCC
SOURCE: Sony KP-57WS510 Convergence issue?
There should not be a need to replace the chip if the fuse below the convergence chip is blown. Check to see if there is a short in the convergence output (after the fuse). If nothing is seen then replace the fuse and see if it works.
SOURCE: Image Distorted
This is a classic convergence problem. Please confirm that your model is 51H84 and whether or not you intend to repair this yourself. You will need to know how to solder. If you wish to attempt the repair, confirm the model and update this and I'll provide you with details and instructions.
Dan
SOURCE: My screen image is concave, like a funhouse
Ur convergence it dead,know how to solders?Buy a convergence kit for replacement.Tries these websites for convergence kit.Tv repair World.com or Tv Repair Kits.
