Question about Archos Computers & Internet
Cannot connect to PC.No driver CD supplied - Archos Computers & Internet
Posted by debanjandoc on
Anonymous
    Sergeant:
  • 269 Answers
Not knowing band/model of the archos or pc  i will suggest that you start at archos support than input your various info to get your driver/software here is the link http://www.archos.com/support/support_tech/updates.html?country=us&lang=en
i hope this helps you and please vote for me
[cut and paste backup link]
Posted on Dec 05, 2010
How do you connect an acer aspire 4745G to a printer?.please I need help immediately for a thesis paper dued
Connect the printer to the computer with the supplied printer cable and then install the printer driver on your computer. The printer driver is supplied with the printer on a CD.
Oct 04, 2010 | Computers & Internet
How can i install my Canon LBP 2900 Printer to my PC?
The safest is way to install the printer driver software to your unit, but a much simplier thing to do is to prepare everything first. cd/dvd ro, driver cd printer. Insert the driver cd to the cd/dvd rom when the PC is already on. Plug your printer to the power supply and connect the USB cable to the PC's USB port and when the system detected the new device, install drivers from the source drive and follow the next instruction until finish. Reboot your PC and you can use you printer now.
Jul 13, 2010 | Canon LASER SHOT LBP-2900 Printer
My pc doesnt detect my dvd /cd
Open your control panel, click on the system icon and see what it indicates about your cd/dvd drive, is it listed?
Try re-installing your drivers. If you are one to mess around with the inside of your computer, make sure the drive cables are properly seated as well as the power supply connector. Check for power at the power supply connector as well.
Sep 25, 2009 | Computers & Internet
How can i connect my nokia 5130 c 2 to my pc
Iam unable to conect my 5130c 2 to pc through data cable as the driver cd not supplied with the pack
Jun 22, 2009 | Nokia 5130 Cellular Phone
How to connect my modem to pc via usb
friend i have same connection so i can tall u better .
if u want to connect through usb just install the cd u got from isp .it will give u the steps.
now connect the usb cable to modem and pc and enter username and password.u will surely have it..
thanks
Mar 28, 2009 | Siemens SpeedStream Modem (4100) (SS4100)
I bought a mobile phone (LG KS360) and it came with a CD-Rom to connect the phone to PC. I installed it and connect the mobile to the PC but it keeps showing me an error message saying " no mobile...
1)please see whether your CD ROM(supplied with your mobile phone) specifications MEETS YOUR COMPUTER SPECIFICATIONS.IF NOT BETTER GO TO MANUFACTURER'S WEBSITE TO DOWNLOAD DRIVERS FOR YOUR OS.
Nov 25, 2008 | LG Cell Phones
I neet Usb drivers for connect my HTC S710 phone to Pc
You can get the programs from the htc website for the programs needed to run the device, you can get the usb program ActiveSync (preVista) from Microsoft.
Oct 17, 2008 | HTC S710 Smartphone
Nokia N72 driver for windows 98
Just follow the following steps:
1) Locate the USB port of your Nokia N72 phone. See Manual if needed.
2) If your mobile phone has a USB Data Cable supplied, connect the end that matches the hub while connect the USB end to your USB port of your PC.
3) If your mobile phone has a CD supplied, this contain the PCSuite software bundled with drivers for your PC operating system.
4) Insert the CD to your CDRom drive.
5) After step 4, you will see a window saying install PCSuite then choose Yes.
6) Choose which operating system. If you use Windows 98, then choose the driver for Windows 98.
7) After installation, reboot/restart tour PC to complete the setup process but never disconnect yet your USB Cables from your mobile phone to PC.
8) Once restarted click on the icon of the PCSuite on your PC, then check if your PC can communicate with your mobile phone and vice versa. To do this click connect via USB if the datas in your mobile phone is seen then connection is correct.
If your problem is USB Driver for Windows 98, i suggest you upgrade your PC operating system to Windows 2000 or Windows XP. Old operating platforms have driver problems when new devices are attached to. But if you choose Windows 98, you will have to browse the internet in search of drivers. Just let me know if you have not found a driver. I'll assist you with this.
Jul 03, 2008 | Microsoft Windows 98 for PC
Need drivers for lg cd/dvd slimline drive [gdr-8082n]
dependant on operating system.
you should not need drivers for cd/dvd drives, as the standard drivers supplied with windows 2000-ME-XP should be sufficent to work the drive.
i,d suggest checking the driver jumper block at the rear of the drive, and seeing if it,s connecting as a master or slave drive, if it,s not being recognised by the system. if the hard-drive jumper ( Small plastic Block ) On the back of the drive is set as Slave, set the CD Drive as Master, or Vice-Versa.
Mike @ compurepair.
Jun 12, 2008 | Computers & Internet
RCA Lyra H100A
You must be running Windows 98 - see if RCA's website has the driver - you must have that driver or the installation CD - there is no other way (unless you get a computer running Windows XP or higher):
1. Insert the supplied installation CD into the CD-ROM drive first.
2. Read the readme file of the installation CD.
3. Double Click “77xinst”, then Restart Computer.
Method Two:
1. Insert the supplied installation CD into the CD-ROM driver and
connect the unit to your PC via the supplied USB cord.
Note: Do not select the charging battery mode after connecting the
unit to your PC. Please see page 4 for details.
2. If the player is recognized by your PC, the “Add New Hardware
Wizard” is activated, and click “Next”.
May 30, 2008 | RCA H100 MP3 Player
Computers & Internet Logo
179 people viewed this question
Top Archos Computers & Internet Experts
Lawrence Oravetz
Andrew Taylor
Andrew Taylor
Are you an Archos Computer and Internet Expert? Answer questions, earn points and help others
