Sony BRAVIA  KDL-46V3000 Television Logo
Posted on Dec 05, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Standby light keeps blinking with no picture - Sony BRAVIA KDL-46V3000 Television
Anonymous
Level 3:
  • Master 455 Answers
  • Posted on Jun 12, 2011
Anonymous
Master
Level 3:
Answers
455
Questions
0
Helped
153206
Points
1043
The Standby/Power light of the TV blinks when there is any internal malfunction in the TV. The self-diagnostic function of the TV will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue.
Few examples are given below; some of the issues may be resolved without the need for service.
1 blink / 2 blinks / 5 blinks: - This indicates that there may be a power-related problem with your set.
3 blinks: - This indicates that there may be a power-related problem with your set. The set will need to be serviced to allow a technician to determine the specific issue that needs to be repaired. If the power light flashes three times in sequence in a Lamp TV, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
4 blinks: - This indicates that there may be a back light or lamp power problem.
6 blinks: - This indicates that there is some kind of audio problem with your set.
7 blinks: - This indicates that there is a temperature problem with your set. Please check to make sure that the air vents on the sides and back of the set are not blocked or clogged and there is adequate ventilation around the television. We recommend that you check and clean the vents periodically to make sure the set receives adequate air flow. If the problem continues, the set will need to be serviced.
8 blinks: - This indicates that there may be a video-related problem with your set. If the flash sequence is not listed above or the light continues to flash, follow the steps below to perform a power reset:
Try the following steps to check if the issue can be resolved.
Turn off the television.
Unplug the television power cord from the electrical outlet.
Let the television remain without power for 60 seconds.
Plug the power cord back into the electrical outlet.
If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
If the issue continues to occur, service may be required.
Thanks for using Fixya.
Why wont my sony kv-30hs420 tv wont turn on? When i try all that happens is the red light will keep blinking seven times!
My TV continues to blink on Standby with Red light ...
https://community.sony.com/t5/...blink...Red-light-flashing.../59141
Jan 12, 2013 - I need help with my Sony TV. The red flashing light keeps going on and off. ITs on standby. can someone guide me as to how to fix the problem. ... I have a Bravia KDL52W3000 with a 7" wide dead pix... Television - Picture & Sound ... What is the exact model number of the Sony TV? Check if the same issue ...
Sony wega tv kp 51ws520 keeps turning off after the standby red light blinks 10x's
problem with str ic need replacement has an internal short need a tech to do it
Sony Trinitron Model KV20FV10- when I turn it on the Sound comes on BUT no picture and the red light for the Standby Times keeps flashing non-stop.
How many times do this standby light blinks. It is fault indications. You can get an idea about the faulty section inside the TV, by counting these blinks occurs at one time switch ON. These are called blinking codes. For more details about blinking codes to Sony brand TVs, check this link. Pull up older posts there. Surf the site with patience.
3helpful
Hlp 5063w on off front button flashing lamp then stanby..hear sound no picture.. shuts off then comes on.
If the lamp and standby lights are both flashing and the timer light is off, check that the lamp cover on the back of the TV is properly positioned in the groove and secured by the screw. Take it off and check that the screws that hold the lamp itself are secure. There is an safety feature that keeps the lamp from turning on when the lamp cover is off.
If the three lights (timer, lamp, and standby) are blinking, then the lamp needs to be replaced. If the timer and standby lights are blinking and the lamp light is off, then a cooling fan isn't working. When only the standby light is blinking and the other lights are off, the unit is overheating and a ventilation area may be blocked.
I hope this helps.
1helpful
Sony kp tv stand by light keeps blinking and no picture
The standby light LED BLINK is in specific numbers, please count that how many time LED BLINKS in specific time and in specific numbers like 1 time 2 time 3 times etc, every blink has its area of fault which processing IC detects, Therefore please count and let me know the number of blinking stand by light and then i can tell you the area of fault and its solution.
Hope you will understand my sayings, if need more clarification write in comments.
thanks for using fixya.
1helpful
STANDBY LIGHT KEEPS BLINKING BUT NO PICTURE OR SOUND
just try unplugging it for a little bit and see how that works.
5helpful
My 36" Trinitron standby lite just keeps blinking..
Hello Nicrod,
Can you let me know how many times that light blinks on your TV? There would be a small interval between blinks and then big interval.
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
