Question about LG 37LG30 37 in. LCD HDTV
Picture too big tops of heads mjssing - LG 37LG30 37 in. LCD HDTV
Posted by jcdewhirst on
Loretta Northcutt
  • LG Master
  • 736 Answers
Press the hd zoom # button or format/aspect button on your cable box/satellite box remote to adjust picture size. If that doesn't work try the below troubleshooting steps.
First make sure that your television is on the right input. i.e your cable box might be connected with both a coaxial cable and a component or hdmi cable. You might be on the input for the coaxial cable by mistake. Next check the resolution of your cable box and make sure it matches what your television can display. For example you should not have your cable box set at 1080i if this is a 720p television. Next make sure it is formatted for a 16:9 television under its (the cable box's) set up menu. Try pressing the wide/view mode/aspect/format button on your television's remote to adjust picture size.
Posted on Dec 05, 2010
How can I make the image on tv screen smaller?
Press the Format button. It's directly below the power button. It has a symbol of a rectangle with a double-headed arrow inside.
Press it to cycle through the different picture shapes.
Sep 10, 2014 | Emerson LC320EM2 32" LCD HD Television
How do i format my philips 40
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?scy=US&slg=AEN&mid=Link_FAQs&new_tmpl=1&session=20100701083748_66.249.65.50&ctn=40PFL5705D%2FF7&dct=FAQ
Sep 06, 2012 | Philips 40pfl3705d/f7 40 Hdtv, Hz Lcd...
Picture too big for screen; cutting off top of heads and bottom of screen
Go to the picture setup of your settings menu.
Somewhere in there are options for selecting picture size.
The options will be similar to: Normal, Wide, Zoom, Stretch
You have probably selected Zoom, try Normal.
May 18, 2011 | Hyundai Q321 32 in. LCD Television
The picture is too big for the screen...heads are cut off and guide is cut off on the top when changing channels
Change the aspect ration in the picture menu for a different apperture.
Hope that helps.
Jan 16, 2011 | RCA Televison & Video
I have an lg tv and picture is to big....cuts the
If you are tuning from cable or satellite you need to change the settings in the picture menu look for options like "stretch" "autofit" etc. cycle through until desired picture is displayed, turn off widescreen setting if you can find it check the manual for options regarding this. If you have it attached to a computer you will need to change the resolution to something smaller like 1366X768 which is the standard 720p resolution for the smaller tv's If there is still a problem it may be
May 21, 2010 | LG 32LG30 32 in. LCD HDTV
Picture is to big for screen
Menu go to setup,go to reset,well be back to factory setting.U will have function to view mode,not than ur video backlight board have problems.
Apr 30, 2009 | Sharp Aquos LC32D41U 32 in. LCD TV
Picture too big.
HDTV's come with selections that will change the screens display, on the remote press the format button and you should be able to find a setting that you desire.
Sep 07, 2008 | Sony KDSR50XBR1 50" Projection HDTV
on your remote push the arrow key to the right or left side. this should change format and go into customer setup and turn of autoformat
Aug 31, 2008 | RCA HD52W59 HDTV Projection Television
Picture is vertically too big the heads dont fit the screen?
This answer is generic because I do not know the particular model:
You should call the tech support for your set. This may be a fault in the way the address processing is being performed for the display. Sometimes, depending on the model, the service rep can fix this by re-loading the firmware for the set's operation. I have seen failures in the main drive processor for the screen cause this. The solution was to change the board.
Jerry G.
Jan 08, 2008 | Samsung LN-T4665F 46 in. LCD Television
Big black box at top of screen
If you mean that a black box appears on the screen, and you can still see the picture around the box, it means that your closed captions are on and set to TEXT. If this is the case, enter the menu, navigate to the closed captions page and set the captions to OFF. If you mean that the top of the picture has collapsed down, the vertical circuit has stopped working correctly and the set should be serviced by a qualified tech.
Sep 15, 2007 | Philips Magnavox 27MS343S 27" TV
LG 37LG30 37 in. LCD HDTV Logo
276 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
