Microsoft Internet Explorer 8 Logo
Joseph C. Agnis Posted on Dec 05, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I want to know on how to uninstall IE8 on my computer i am running a windows XP service pack 3. I just want to install a fresh copy of IE8 . . . . .
Arun Zachariah Zachariah
Level 2:
Scholar:
  • Expert 75 Answers
  • Posted on Dec 05, 2010
Expert
Level 2:
Scholar:
Answers
75
Questions
0
Helped
13165
Points
243
Hi josephc_agni,
You cannot uninstall Internet Explorer 8 if it is set as not removable. This occurs if you install Internet Explorer 8 before you install Service Pack 3 (SP3) for Windows XP. If this scenario applies to you, then you must uninstall SP3 before you can uninstall Internet Explorer 8.
To uninstall Internet Explorer 8, follow these steps:
  1. Close all programs.
  2. Click Start, and then click Control Panel.
  3. Click Add or Remove Programs.
  4. In the list of currently installed programs, click Windows Internet Explorer 8, and then click Remove.
    NOTE: If Windows Internet Explorer 8 does not appear in the list of installed updates, try the alternative step given below.
  5. Follow the instructions to uninstall Internet Explorer 8.
  6. When the uninstall program is finished, restart your computer.
ALTERNATIVE STEP:
  1. Carefully select and then copy the following command: %windir%\ie8\spuninst\spuninst.exe
  2. Click Start, and then click Run.
  3. In the Open box, type Cmd.exe, and then press ENTER.
  4. Right-click inside the Cmd.exe window, and then click Paste to paste the command that you copied in step 1.
  5. Press ENTER to uninstall Internet Explorer 8.
DUSHYANT SINGH
Level 2:
Sergeant:
  • Expert 369 Answers
DUSHYANT SINGH
Expert
Level 2:
Sergeant:
Answers
369
Questions
0
Helped
95702
Points
819
Go add remove program through controll pannel and go to installed components and just uncheck the Internet explore and ok it should remove the explorer from your system and later you can download and install any explorer you need.
thanks
Can service pack 3 run on a 32 bit windows xp home computer
The simple answer is yes. Assuming this is a legal copy of XP just use Windows update service and it will install all the necessary updates.
tip
Removing IE 8
<p>If you have problems with Internet Explorer 8, you might want to try <a href="http://support.microsoft.com/kb/956197/LN/">Compatibility View</a> or our <a href="http://support.microsoft.com/gp/pc_ie_v8intro">guided help</a> <span> </span>to see whether you can fix the problem. However, if you just want to uninstall, or remove, Internet Explorer 8, this article helps you do that.<br /><br />When you remove Internet Explorer 8, your earlier version of Internet Explorer is restored with your customizations (such as add-ins, Favorites, and your home page).<br /> <p><b>Resolution:</b><br /> <p>To uninstall Internet Explorer 8, follow the instructions for your version of Windows. To follow these steps, you must be logged on to Windows as an administrator<br /> <p><b>Important:</b> You cannot uninstall Internet Explorer 8 if it is set as not removable. This occurs if you install Internet Explorer 8 before you install Service Pack 3 (SP3) for Windows XP. If this scenario applies to you, then you must uninstall SP3 before you can uninstall Internet Explorer 8. For more information about this issue, click the following article number to view the article in the Microsoft Knowledge Base: <br /> <p><a href="http://support.microsoft.com/kb/950719/">950719</a> You cannot uninstall Internet Explorer 7 or Internet Explorer 8 after you install Windows XP Service Pack 3<br /> <p>To uninstall Internet Explorer 8, follow the instructions for your version of Windows. To follow these steps, you must be logged on to Windows as an administrator. <br /> <p><b>Steps for Windows 7</b><br /> <p>To uninstall Internet Explorer 8, follow these steps: <br /> <p>1. Close all programs. <br />2. Click StartCollapse this imageExpand this image, and then click Control Panel.<br />3. Click Programs and Feature.<br />4. In the tasks pane, click Turn Windows features on or off.<br />5. In the list of windows features, clear the check box next to Internet Explorer 8.<br />6. You receive a warning message in a pop-up window. Click Yes.<br /> <p>Internet Explorer 8 will now be uninstalled. The system will restart after the installation. <br /> <p><b>Steps for Windows Vista or for Windows Server 2008</b><br /> <p> loadTOCNode(3, 'resolution'); To uninstall Internet Explorer 8, follow these steps: <br /> <ol> <li> Close all programs. <li> Click Start</b>, and then click Control Panel</b>. <li> Click Uninstall a Program</b> under the Programs</b> category <li> In the Tasks pane, click View installed updates</b>. <li> In the list of installed updates, double-click Windows Internet Explorer 8</b>. <br /><br /><b>Note:</b> If Windows Internet Explorer 8 does not appear in the list of installed updates, try the <span><b>alternative steps for Windows Vista or for Windows Server 2008</b></span>. <li> In the Uninstall an update</b> dialog box, click Yes</b>.<br /><br /><b>Note:</b> If you are prompted for an administrator password or for confirmation, type the password, or click Continue</b>. <li> Follow the instructions to uninstall Internet Explorer 8. <li> When the uninstall program is finished, restart your computer. </li></ol> <p><b>Steps for Windows XP or for Windows Server 2003</b><br /> <p> loadTOCNode(3, 'resolution'); To uninstall Internet Explorer 8, follow these steps: <br /> <ol> <li> Close all programs. <li> Click Start</b>, and then click Control Panel</b>. <li> Click Add or Remove Programs</b>. <li> In the list of currently installed programs, click Windows Internet Explorer 8</b>, and then click Remove</b>.<br /><br /><b>Note:</b> If Windows Internet Explorer 8 does not appear in the list of installed updates, try the <span><b>alternative steps for Windows XP or for Windows Server 2003</b></span>. <li> Follow the instructions to uninstall Internet Explorer 8. <li> When the uninstall program is finished, restart your computer. </li></ol> <p><b>Alternative steps</b><br /> <p><b>Alternative steps for Windows Vista or for Windows Server 2008</b><br /> <p> loadTOCNode(3, 'moreinformation'); To uninstall Internet Explorer 8, follow these steps: <br /> <ol> <li> <p>Carefully select and then copy the following command: <br /> <p><b>FORFILES /P %WINDIR%\servicing\Packages /M Microsoft-Windows-InternetExplorer-8*.mum /c "cmd /c echo Uninstalling package @fname && start /w pkgmgr /up:@fname /norestart"</b><br /> <li> Click Start</b>, and then type <span>Cmd.exe</span> in the Start Search</b> box. <li> In the list of programs, right-click Cmd.exe</b>, and then click Run as administrator</b>.<br /></li></ol> <li> Right-click inside the Administrator: Command Prompt window, and then click Paste</b> to paste the command that you copied in step 1. <li> Press ENTER to uninstall Internet Explorer 8. <li> When the uninstall program is finished, restart your computer.</li> <p><b>Alternative steps for Windows XP or for Windows Server 2003</b><br /> <p> loadTOCNode(3, 'moreinformation'); To uninstall Internet Explorer 8, follow these steps: <br /> <ol> <li> <p>Carefully select and then copy the following command: <br /> <p><b>%windir%\ie8\spuninst\spuninst.exe</b><br /> <li> Click Start</b>, and then click Run</b>. <li> In the <span>Open</span> box, type <span>Cmd.exe</span>, and then press ENTER. <li> Right-click inside the Cmd.exe</b> window, and then click Paste</b> to paste the command that you copied in step 1. <li> Press ENTER to uninstall Internet Explorer 8. <li> When the uninstall program is finished, restart your computer.</li> <li> <b>More Information:</b></li> <li> After you uninstall Internet Explorer 8, you may notice Application event log errors after each reboot. To resolve this problem, delete the following Internet Explorer User Accelerators and Internet Explorer Machine Accelerators registry keys in HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon\GPExtensions: </li> <li> {7B849a69-220F-451E-B3FE-2CB811AF94AE} {CF7639F3-ABA2-41DB-97F2-81E2C5DBFC5D}</li> <li> <b>The information in this article applies to:</b></li> <li> Windows Internet Explorer 8</li></ol>
on Mar 15, 2011 • Computers & Internet
tip
How to uninstall Internet Explorer 8 if SP3 is installed after the IE update?
Here are the steps to uninstall Internet Explorer 8 Beta from the computer:
Note: These steps are only for Windows XP with Service Pack 3.
1) Click on Start, click on my computer.
2) Browse to C:\WINDOWS\
Note: You will have to unhide the files and folders:
1. Start Windows Explorer. To do this, click Start, click Run, type userinit.exe , and then click OK.
2. Click Tools, and then click Folder Options.
3. Click the View tab.
4. Click Advanced Settings.
5. Under Hidden files and folders, click Show hidden files and folders, click to clear the Hide Protected Operating System files (recommended) check box, and then click OK.
3) Double click on the folder “ie8′.
4) Double click on the folder “spuninst”.
5) Double click on the executable “spuninst.exe”.
Follow the prompts and then click on “Finish” to restart the computer.
Your Internet Explorer will roll back to the previous version (IE7 or IE6).
I can perform every possible solution recently installed fresh windows xp but still facing this problem "page cannot display" my internet connection status is ok n it will work normal in other pc
Hi
I had the same prob when i installed a fresh copy of xp on my friends computer
the laptop was only running internet explorer 6 and service pack 1
after wasting severall hrs googling reasons why i ended up
downloading service pack 3 onto a pendrive then loaded it onto the laptop and that seemed to do the trick as i believe that service pack 3 has internet explorer 8 on it as well as other important updates
CAN I USE INTERNET EXPLORER 8 IN WINDOW XP
it is required to install Windows XP Service Pack 2 or Windows XP Service Pack 3.
http://www.microsoft.com/downloads/en/confirmation.aspx?familyId=341c2ad5-8c3d-4347-8c03-08cdecd8852b&displayLang=en
Open the above link and click on "Start Download" for IE8
1helpful
Windows XP Service Pack 3 disables Vuze from connecting
you should be able to uninstall SP by going into add/remove programs make sure show updates is checked, drill down to "Windows XP Service Pack 3" and remove..I'd also dump IE8..been known be a problem as well
from MS website,if that doesn't work there are alternate methods
http://support.microsoft.com/kb/950249
Don't forget to rank the advice!
http://www.aa1consulting.com
Internet Explorer 8
hi,
when you open the trouble shooting icon that gives the exact message.
1. remove the traces of IE 8 if there are any.( start - run - IE8 - spuninst - double click on windows service pack uninstall.this is not applicabe for vista)
2. uninstall the security software completly. if its norton use the following link : www.symantec.com/nrt. it it's mcafee us this link: www.mcpr.notlong.com .
3. then install IE8. later install the security software back in the computer.
2answers
Installed IE8 and I hate it, want to go and reinstall IE7
Try uninstalling IE8 and it should put IE7 back in. Failing that uninstall 8 then 7 then update to 7. Of course if they want you to use 8 then they probably took 7 off the udate page. Then you could backup hard drive, re-install windows, put in the service packs and get back to IE7. Option 3: learn to live with 8.
1helpful
2answers
Intel webcam cs430 EXTERNAL VIDEO INPUT SHOWS BLUE SCREEN-NO VID
I had the same problem (blue screen from external cam). I read a few unrelated posts that talked about USB2 vs USB 1 and internal PCI vs external USB hub so thought I'd try a few things. I unplugged my CS430 from an external USB1 (I think - it's a Belkin iPOD synch base with 5 USB ports) hub and plugged it into the front chasis mounted USB 2.0 ports on my Dell Dimension E310 and voila!!! the external cam works and no need to mess around with SP3 etc. Hope this helps.
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
