SOURCE: xerox 390 error code 1
> Support & Drivers > WorkCentre 390 Laser All-in-One Support > Search Results > How To Clear a Fuser Error Message
Solution: Perform a RAM Clear
Make Printable
Email this page
Performing a RAM Clear will restore all of the WorkCentre's
settings to the factory defaults. It will also clear all faxes in
memory, Speed Dials, One-Touch Buttons, Group Speed Dials, your System
ID, and any other stored information.
NOTE: If you are able to print, it is a good idea to print
out your Phone Book before performing the RAM Clear, to assist you in
reprogramming your Speed Dials and One-Touch Buttons. It is also
recommended to print out your System Data List to assist you in
reprogramming your system settings. If you are not sure how to print
your Phone Book or System Data List, refer to Related Items at the
bottom of this page.
To perform a RAM Clear:
SOURCE: LSU Error
I will simply send you what the documentation states ok?
Either a laser main board or loose connection to either.
SOURCE: workcentre c2424 is showing system error 39,003.40:117010
That is a document feed or scanner fault. Often times it is simply that molex connector working loose. It is the connector mounted vertically next to the main power cord on the right rear side of the machine. That bottom screw can be dificult to tighten. What I would try first is to shut the machine off, unscrew and disconnect that conntecot totally then firmly slide it in and get both the top and bottom screwss tight. Like I said, the bottom thumb screw can be hard to tighten even with a screw driver because it is a pretty soft rubber the tighteners are made out of.
If that doesnt work. go to the back and disconnect the document feed to scanner cables and reconnect. Other than that, you pretty much have to replace the feeder/scaner assembly since very very few parts are spared for that .
SOURCE: my xerox workcentre pe 220 machine have an error message on "low heat error"
You will have to replace the fuser.
