HP DeskJet F380 All-In-One Printer Logo
Posted on Dec 05, 2010
Even after removing thye paper the status shows papaer jam. and unable to print
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Dec 05, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
126
Points
Try to use some compressed air, on the back inside of the printer, probably one of the sensors is jammed with dust or a tiny piece of paper.
Mfc-j6535dw unable to print 44 then 43
Unable to print 44 indicates a mechanical problem other than the paper jam error message. Things you can try:
Turn off the printer. Unplug it from the wall. Wait a minute. Plug it back in.
You appear to have taken the next step of removing paper stuck. Put in a single sheet of glossy A4 size paper in landscape position into the manual feed slot.
Print a "Print Quality Check Sheet" to see if the issue is resolved. Press the up or down arrows on the touchscreen to display the "Improve Print Quality" option. Press "Improve Print Quality". Then press "Check Print Quality." Then press "Start."
If "unable to print 44" shows up, then the printer will require a service unless a call to Brother customer service resolves the issue.. "Unable to Print 44" (brother-usa.com)
After any printing it say papaer jam. jam40
The paper feed path is not clear - remove any pieces of paper or debris if this doesn't help use dry paper because moisture can do this as well
1helpful
2answers
Papaer jam in toshiba e-studio 181
try changing the paper u use..... i recommend typex or xerox...
Colour printing not working
Hi ,
While printing go to the printer settings nad check if any Black print option is clicked. Also check the color cartridge status.
1helpful
2answers
I have a lexmark x2550 printer. I was trying to print a document but the paper became jammed so I removed it. I threw away the jammed paper and tried to print the document again loads of times. Everytime i...
If its not taking the paper, it may be that the paper you are using is not the right type. Some papers are too smooth or shiny to allow the guide wheels and platten ( roller) to grip the paper. This oftemn results in no paper or only one side of the paper being caught and then it jams.
Wipe the platten with alcohol, as welol as thye guide wheels if you can see them. Ink tends to stick on them and the platten and becomes shiny ans so paper will slip. Also try a heavier grade paper to see if that rectifies the problem
1helpful
Paper jam. caused error print unable 30
"Machine Error 30" (or "Unable to Print") indicates either a simple problem such as a paper or part of a paper stuck inside the machine, which of course is solved by opening the machine as much as possible and remove the reason for the jam.
Even a ripped part of a paper will be able to cause the paper, so it's important to be careful when taking jammed paper out to not rip the paper (do this by carefully pulling the paper among the same way as it would go when printing, not the opposite direction).
However, if that doesn't work, the error is mechanical (but still most likely caused by the jam, either a sensor getting dirty and unable to do it's work, or actually getting broken), and there isn't much you can do. If the message comes back right after turning on the machine, you'll have to have service performed on the machine.
11helpful
Dell 3110cn Laser Printer No paper detected 024 965
remove papaer tray and look for a small black arm which should swing freely it most likely hangs down from the base of the machine or it may be jammed up into the slot it enters to activate the papaer detect switch
LUV
JAFDEE
3helpful
2answers
Change papaer size and frequent papaer jams
OK it seems to be a problem with pick up clutch and vertical feed rollers ( When you open the left door and hinge in level of cass you will see axis with the tree little rollers- clean it with alcohol or water).Pick up clutch is better to replace it FK2-1068 (europe code).
Printer ERROR "Unable to Print 50! Unable to Print 30!" ???
WONT PRINT UNABLE TO PRINT , PAPER JAM
CLEANED PAPER JAM, CANT SEEM TO FIND ANY THING MORE TO DO TO IT
2helpful
LCD Error message: Paper output slot. Thye paper is jammed. clear the paper and press OK.
A jam sensor may be stuck or have something stuck on it, causing the machine to think it is jammed. These sensors are normally located where the paper feeds into the printer, and where the paper exits the printer. Try forcing a sheet of paper through the machine in the direction paper normally. feeds. This may free up the jam sensors.
k24674
Grand Canyon Tech
Grand Canyon Tech
