Coby MP601 MP3 Player Logo
Posted on Dec 05, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Have a blank Coby MP601 2gb .... bought it but the device is empty ... it is a good drive but the media program or drivers wasn't on the player .... would like to encode some clips it's for my daughters Christmas present ... tried generic program it said MTV format but the play say "unknow format" .... any one know what video converter works with this thing?
Muntejaya Ginting
Level 3:
  • Master 10,422 Answers
  • Posted on Feb 19, 2011
Muntejaya Ginting
Master
Level 3:
Answers
10422
Questions
Helped
2469751
Points
19564
2answers
Soft ware
Try to reset the devise and update the media player. Can be done from the Coby website. Also make sure the cord didn't go bad. I've had more than one cable go bad on me.
1helpful
When I plug in my mp3, i cant sync because wmp doesnt recognize the mp3 at all. I was trying to find software or driver download to help fix. please help!
Hi, Looking for Drivers.
In order to download the right driver for a Coby MP3 player, you'll need to go to the Coby website support page where you can download software drivers (See Resources). To find the driver you need, you first need to identify which device you're using. Select "MP3 & Portable" under where it says "Select a Product" on the first box on the left. In the second box, it will be "MP3 & MP4 players." The final box lists all of the MP3 and MP4 players that Coby produces. You'll need to find your MP3 player in this list. The designation will be letters and number such as "Mp200". It should be listed on the box. Once your MP3 player is selected, clicking on the "Submit" button at the bottom will cause the text "Available Downloads for Mp200" (or whatever your MP3 player is called) to appear towards the bottom of the screen. Underneath, there should be a link for "Driver," if there is one available for your player. Clicking on that will allow you to download it.
Installation
If you click "OK" on the download screen, your driver should install. It will likely be in a ".zip" format, which means another program is needed to "unzip" the file so that you can install it. An example of such a program is WinRAR (See Resources). This program needs to be installed first, before it can be used to unzip your driver file. After you've downloaded the program, opening the installation file will begin the installation process. Choose a directory for where the program will be installed. After installation is complete, you can go back to the ".zip" driver file. Double-clicking on the file will bring up a new window. You can now drag your driver files from inside the .zip folder to any folder on your computer that you wish. There will be a file marked "Setup" among the unzipped folders. Opening this file should allow you to install the drivers you need on your computer.
Also Coby mp3 player not recognized by the computer.
Why is my Coby player not being detected by my computer when I connect it?
This may be caused by one of the following:
1. Minimum system requirements were not met.
2. Corrupted drivers.
3. Computer restrictions.
4. Power issue.
To resolve this issue, try the following solutions:
SOLUTION 1 - For brand new player or first time connecting to this computer.
For Windows XP users: verify the following operating system requirements are met.
- Windows XP SP2 or higher
- Windows Media Player 10 or higher
Download and install the latest Windows Media Player if it's not installed.
For Windows Vista users: If the player is seen in My Computer when using MTP mode, but not showing in Windows Media Player.
- Download the hotfix from http://support.microsoft.com/kb/939211.
- Run the hotfix.
For MAC users, see player not recognized by a MAC OS
NOTE: If you are trying to connect to a Computer at work that is part of a network, there may be user right restrictions that are set to disable access to new hardware or stop any program installations. You may need to check with your IT administrator to see if this is causing the problem.
SOLUTION 2 - Refresh the driver
STEP 1 - Connect the Coby mp3 player to the PC
The screen on your player should turn on, show 'Connected' and indicate the battery charging or full.
- If the player does not turn on try other USB ports or on another computer if one is readily available. Ensure you are connecting directly to the computer USB port and not to a USB hub.
- If there is nothing showing on the screen and the player does show up in as a storage device in an explorer window, then the screen is just not working.
If you receive the error "USB Device Not Recognized" on the computer, the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
STEP 2 - Check under Device Manager
1. Right-click My Computer, and select Manage.
2. Click Device Manager on the left pane.
NOTE: Coby mp3 player can connect to your computer in MSC or MTP mode. Exceptions are Coby mp3 player Connect and Coby mp3 player Express which only use MTP mode. MTP mode is the recommended and default method for Coby Players when used with Windows OS.
The Coby player will show up on Device Manager's right pane as:
1. USB Mass Storage device (if the player is set to MSC)
2. Portable Device (if the player is set to MTP mode)
If there is a yellow exclamation point (!) or question mark (?) beside the device, try to refresh the drivers.
STEP 3 - Refresh the drivers
1. Right-click the entry with the error mark, select Uninstall.
2. On the top menu, click Action then select Scan for hardware changes.
NOTE: If a device with yellow exclamation point (!) continually appears and disappears, then the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
Hope that helped..
5helpful
How do I get coby media manager back?
For the MP610, to get Coby Media Manager back, goto:
1) cobyusa.com in internet explorer
2) select Support in the page top
3) select Coby Media Manager Fix for MP822:
The fix is the complete program actually, for installation of
Coby Media Manager.
Read the page: select and install the matching file for your operating system.
Run Coby Media Manager
In the page top select Tools > Device Manager...
Select the MP-610 (AC) or (AL) version from the devices list
Add >>
OK to setup your device
note
AC and AL version works with different video files
AMV and MTV
1helpful
Installation
If you have deleted the program from your computer, you should be able to plug the Coby player (TURNED OFF) to the computer and re-install it.
If Coby Manager program is no longer on the Coby player (If you re-formatted the player), you can get a copy of the MANAGER here:
CobyMedia Manager fix for MP822 (Windows XP/2000/Vista)
Don't let it throw you that it says it's for the MP822 - it also works great for the MP610
1. Install Coby Media Manager from download
2. Open Media Manager
3. Plug your COBY player (THAT IS TURNED OFF) into the USB port - it will show up in the "DEVICE" tab
2answers
I just bought a Coby MP600-4G MP3 player. but it doesn't show in my computer.
if u have a installer cd with the device then
please install the driver then plug your device
in the connectivity cable.
1helpful
I deleted the coby software on my Coby MP300
Easiest solution that comes to mind is find someone with the same player. see if you load the drivers on your pc in a file if the you can load it as a new device and open it using drivers on your pc. Just a thought. then load the files back on the unit once you get access.
3helpful
Can't seem to transfer music files to my new MP610-2G
The cobyt player is completely incompatible with iTunes. If you have songs that are in mp3 format, you can use Windows Media Player to transfer the songs to your Coby. If your songs are already in AAC (iTunes) format, you can use a free program like Media Monkey to convert UNprotected AAC files to mp3 format so that they will be usable with your Coby. Media Monkey is not capable of converting protected files.
-Tha Mp3 Doctor
Usb drive not recognized
try to re-install the drivers for the mp3 player...that might work...or try using other programs to download music rather than windows media player. that is not the best thing to use to get music...try something like limewire, ares or even i-tunes.
Top Coby Audio Players & Recorders Experts
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
Are you a Coby Audio Player and Recorder Expert? Answer questions, earn points and help others
