Question about Proview PL713S 17" Flat Panel LCD Monitor
I have a Proview 17" monitor, model number 700p
Posted by nyohoki on
5 Related Answers
Anonymous
  • 116 Answers
SOURCE: green led light flashing on 700p proview flat panel and no picture
You need to replace the power supply! I work with these all of the time, the most common problem with thes montiors is the Power supplies do no generate enough charge to power it up to display an image! If the Power supply does not work I would look into getting a new monitor because then it is truly involved! Bad inverter, or blown LCD. I speculate that if your not getting any video after trying the new cord. replace the monitor! Sorry!
Posted on Nov 26, 2007
Anonymous
  • 6 Answers
SOURCE: Proview 700P power problem
Probably a bad inverter board.
Posted on Feb 10, 2008
Anonymous
  • 2351 Answers
SOURCE: Need help: ProView 700P Silver LCD Monitor
Your ProView 700P Silver LCD Monitor does not need a driver. Windows see's it as a plug & play monitor. Suggest you have the monitor repaired or refurbished by a pro.
Posted on Feb 26, 2008
Anonymous
  • 2120 Answers
SOURCE: How to use this Proview LCD Monitor 17" 700P AS A TV Screen
No. The newer LCDs can do both. But they are a TV to start with the option to hook up a Desktop.
Posted on Feb 08, 2009
jeremyboden
  • 16 Answers
I have a similar problem.
Switching the screen off (front panel button) and on again after waiting a few seconds fixes it.
This is a recent problem, so I'm expecting it to get worse and worse until one day!!!!!!
Posted on Feb 10, 2009
Blurry screen on proview tft monitor
Try to adjust the picture adjustment.Like the contrast and brightness
Oct 05, 2010 | Proview PL713S 17" Flat Panel LCD Monitor
Where does it go? what does it look like.
heres the proview site http://www.proview.com/Product/Product_Sub-category.aspx?ii=212
I suspect it uses a kettle type plug - that looks like this https://www.cashgenerator.co.uk/_images/product-details/BE991.jpg and the connector looks like this http://acimg.auctivacommerce.com/imgdata/0/1/2/8/8/9/webimg/1310841_t.jpg See what you have on the back of the monitor - if it does look like that connector - those cables are avaibable at most store - what country are you in ?
Apr 15, 2010 | Proview PL713S 17" Flat Panel LCD Monitor
My monitor does not work right. it says vga not support.. its a proview 17" flatscreen..active matrix tft lcd
I suspect your Computers Display settings need adjustments and or a Driver from Proview installed...therefor if you can get on the net, I would look at FAQ's on Proviews Website, i.e:
http://www.proview.net/Support/FAQ_Question.aspx?pi=2026
hope that helps,
Bastian
Jun 02, 2009 | Proview PL713S 17" Flat Panel LCD Monitor
Feb 08, 2009 | Proview PL713S 17" Flat Panel LCD Monitor
Dead Proview 700p monitor
my monitor samston 17`` have a problem with screen ten minute after on it`s become on / off screen ( it`s black, it`s white ) when it`s happen the wording can read, when it`s on.
Jun 25, 2008 | Computers & Internet
Beware this monitor! PL713s
Probably a good solution. 17" LCD's are pretty inexpensive these days and probably cost as much to diagnose and fix this one. You can purchase on-line as well. www.tigerdirect.com www.newegg.com Good luck
Aug 27, 2007 | Proview PL713S 17" Flat Panel LCD Monitor
Proview EM-170
Hi, if ya go to http://pinouts.ru/Video/ Ya bound to find all ya need here. good Luck.
Aug 02, 2007 | Proview PL713S 17" Flat Panel LCD Monitor
Proview PL713S 17" Flat Panel LCD Monitor Logo
Top Proview Computers & Internet Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Tom Chichester
Are you a Proview Computer and Internet Expert? Answer questions, earn points and help others
