Question about Philips Magnavox 42MF521D/37 Television
I have no volume on certain channels - Philips Magnavox 42MF521D/37 Television
Posted by cbcarter1362 on
Anonymous
    Problem Solver:
  • 5 Answers
The most common problem with no volume only on certain channels is the TV is programmed for 2nd Audio, also referred to as SAP which is a feature activated to transmit a second language such as Spanish. If you push your menu button on your remote control you can toggle over to Audio Menu. Then find the feature that allows you to adjust the sound for Mono, Stereo or 2nd Audio (SAP). Adjust the menu to highlight Stereo and that should cure your problem.
Hope this helps with your particular problem.
Posted on Dec 07, 2010
Is there a way to set the volume so i dont have to keep changing them all the time
hello, are you referring to the volume of the TV set when you change channels? to reiterate every time you change channels the volume also changes? in this case I do not want to speak too much but I'm almost certain that television providers are required to adhere to a volume leveling standard which would require television broadcast stations to broadcast at a certain volume level for unity. Are you watching cable television? I happen to know that not all cable television providers level they're broadcasting some do.I notice that you are using a CRT unit are you attempting to use a converter box with the unit? If you are using a converter box there may be a chance that volume level is one of the options in the menu, I can not say there is much at all you can do about this.
As an alternative your television set maybe damage and the volume maybe adjusting randomly or in a way other than intended.
Good luck and thanks
Questions? Just ask!
Nov 25, 2015 | Televison & Video
Sony KDL-40S2010 " LCD TVThe monitor is not working. Last week on certain channels it was bitmapping. Volume is on no picture
this is true, check the main board to the power supply board voltage should be 12volts and 5 volts and 24 they should be marked by the plug ,if voltages are there then the main board is your problem,./
Mar 28, 2014 | Sony BRAVIA KDL-40S2010 40 in. LCD...
VOLUME WILL NOT WORK ON CERTAIN CHANNELS ON MY SANSUI TELEVISON
Make a hard reset to this set. Just unplug the TV from AC mains wall socket, and re-plug it back after 3 minutes or so. This must rectify your TVs problem.
Nov 14, 2012 | Sansui Televison & Video
Interment or no volume on certain channels.
make sure set not set to sap mode as this can blank audio on certain channels
Sep 03, 2012 | Panasonic TC-P42X1 41.6 in. Plasma HDTV
I have just hooked up my Nintendo Wii Console. I cannot figure out how to get it on a certain channel or onto the IMPUT channel so that I can access my Wii. Since I cannot currently find my remote, is...
If there is a menu button on the TV, you can usually go into the menu, use the channel and volume buttons to scroll and look for an input selection prompt. If there is no option in the menu, you will have to find the remote, buy a universal remote, or check to see if your phone is compatible with a remote app.
Jan 09, 2018 | RCA E13209BC TV
No volume on certain channels
If you are using an antenna to recieve digital channels, if the signal strength is low on certain channels the sound will not be tuned in. Try adjusting the antenna. If it is cable there may be a problem with the cable run.
Dec 27, 2009 | Dynex Televison & Video
Trouble with volume on certain channnels
If you get good audio on most and then low or very low audio on certain channels then call you cable company and have them inspect this problem. It is their business to get both good video and audio to you.
Sep 10, 2009 | Insignia Digital-to-Analog Converter for...
Left channels not working
Check out the left channel amp stages - your issue is there.
Apr 30, 2017 | Yamaha RX-V395 Receiver
Channel memory reset
Bryan,
Usually the menu can be accessed from the buttons on the console, sometimes by pressing a "menu" button but other times by pressing both Volume or Channel (+ AND -, UP AND DOWN) buttons simultaneously. Menu levels are usually selected with one or the other of Volume or Channel, and toggles/selections with whichever doesn't do the levels.
Nov 05, 2007 | Sharp 27K-S300 27" TV
Philips Magnavox 42MF521D/37 Television Logo
185 people viewed this question
Top Philips Televison & Video Experts
ThaMp3Doctor
ThaMp3Doctor
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
