Question about Fender Stevie Ray Vaughan Stratocaster Electric Guitar Microphone
I have a Fender SRV ...serial # 918128..any idea what year it was made without removing the neck?
Posted by rfaa on
1 Related Answer
AndrexT
Andrew Taylor
  • 33973 Answers
SOURCE: year of fender telecaster serial number nm9856341
This site too. Guitar Nucleus Fender Serial Numbers
Posted on Oct 27, 2015
Where can I find the serial number on a Japanese made bass guitar it is a fender jazz bass 4 string and how much did this bass guitar cost brand new or how much are these bass guitars cost new today?
Jon has told you about the serial number.
Don't get Fender Fenders confused with Squier Fenders either.
Once you know the serial number you should be able to find out the year here
http://www.guitardaterproject.org/fender.aspx
Then you could try Googling:
"reverb.com Fender Jazz Bass (year)"
and you will see a range of used prices.
Aug 04, 2018 | Fender Music
I bought a used black Fender Stratocaster about 20 years ago with the serial # H 035195 silkscreened on the headstock. At the base of the neck near the body, it has stamped " Made in USA".
I suspect the H is really an N, which would place it.1990-91. As long as the adjustment screw for the truss rod is at the base of the neck. The plugged top end isn't a concern. Your best source of info is to contact Fender customer service directly. Here's the link-
Contact Fender Musical Instruments Corporation
Dec 18, 2016 | Fender Music
V130147 fender Stratocaster reissue serial number .Im trying to find out what year it was made I think I purchased it in early 90s late 80s
That serial number could be for a guitar was made in Corona California, but it does not give the year, which should be visible on the neck of the guitar.
It could be for a guitar made in the Fuji-Gen Japan plant, in 1996-1997, in which case it should show a neck decal "Made in Japan".
https://support.fender.com/hc/en-us/articles/212774746-How-can-I-find-out-when-my-American-made-instrument-was-manufactured-
Dec 05, 2016 | Fender Music
Fender strat serial number DZ0067060
Ok, this is going to be a lot of information. Let's start with the "D"; this usually means that the instrument is a "Deluxe" version. This would suggest it is an American Deluxe Strat. But Fender, themselves even admit that this letter ended up on some American Standard instruments. The second letter is EXTREMELY complicated and hard to explain. From the 1970's through recent years, Fender has used an "S", "E", "N", "Z", or "X". Here is the complicated part; "S"eventies, "E"ighties, "N"ineties, "Z" = 2000-2009, "X" = 2010 - present ;). The zero following the number suggests that this is a 2000 American Deluxe Strat. Keeping all of this in mind, there is another slim possibility. Fender has always used bolt on necks. Leo Fender decided to do this for a couple of reasons. They were cheaper to assemble, easier to work on, and easy to replace. Fender produces many replacement necks and they all have serial numbers on them. The previous owner could have potentially replaced the neck on a standard or even a made in Mexico Strat with an American Deluxe neck with a different serial number. I know this is a lot of info and the serial numbers do go more in Depth than just this, but more than likely you have an American Deluxe Strat. Good find!
Sep 01, 2014 | Music
Woud you check fender serial number z6268670
Your guitar was made at the
Corona Plant (Fender), USA
in the Year(s): 2006 - 2007
Jul 26, 2014 | Fender American DLX Stratocaster V Neck...
I would like to know what year my fender stratocaster custom body guitar serial Number V033170 was Made and its aproximate value
This guitar is from the U.S. Vintage Series
made at the Corona Plant (Fender), USA
The Year cannot be determined from serial number.
However, you can remove your neck and check the date there.
Worth: $800- $1000
Jul 24, 2014 | Fender Musical Instruments Corporation...
What year was a fender stratocaster serial number 33170 made?
in the Year(s): Cannot be determined from serial number,
however you can consult this chart showing the
corelation between serial numbers and dates found on the neck
Fender MIA RI Serial Number vs. Neck Date (Note the earliest I'm seeing is mid 80s)
Have a fender strat serial V019217
It is a US strat! Congrats! Guitar Info This guitar is from the U.S. Vintage Series
Fender: Corona Corona factory was opened in 1985, Corona California, with major guitar production starting in 1987. With the addition of a custom shop in 1987 the plant currently employs about 700 workers. Apart from general and Custom Shop Fender instruments and amplifiers, it also encompasses Guild acoustic & electric guitars.
May 19, 2014 | Fender Starcaster Strat Electric Guitar -...
Where is V193037
May 12, 2014 | Fender Starcaster Strat Electric Guitar -...
I have fender custom telecaster V118552. \do
1982 was the first year for US Vintage Series and V-prefix serial numbers. You have to remove the neck in order to see a possible date stamp, either on the neck, or the body. So could be from 1982-to present as far as the year.
Feb 08, 2010 | Fender Stevie Ray Vaughan Stratocaster...
Fender Stevie Ray Vaughan Stratocaster Electric Guitar Microphone Logo
65 people viewed this question
Top Fender Audio Players & Recorders Experts
 Grubhead
Grubhead
Tom Chichester
JonSnell Electronic
JonSnell Electronic
Are you a Fender Audio Player and Recorder Expert? Answer questions, earn points and help others
