Woods 49556 / TD1300 manual
http://waterheatertimer.org/pdf/Woods-49556-TD1300.pdf
http://waterheatertimer.org/Woods-timers-and-manuals.html
How to program timer.
Plug timer in until rechargeable battery is charged and display shows.
Unplug timer to program
Set current time.
Hold in reset button for two seconds to clear memory
Press and hold TIME button to select 24 hours so there is no problem. Release Time button.
Press and hold SET button.
MO is flashing, and represents MOnday. TU for TUesday. WE TH FI SA SU
Continue holding down SET button, and press ? ? until current day displays.
Release SET button.
Press and hold SET button again, and Hours will flash
Continue holding down SET button, and press ? ? until current hour displays.
Release SET button.
Press and hold SET button again, and Minutes will flash
Continue holding down SET button, and press ? ? until current minute displays.
Release SET button.
Press SET button again and current time and day will display.
Programing overview:
Set up to 20 on-off programs.
You can select individual days, or groups of days, or all days of the week
For example MO-SU is all days of the week
For each ON time, you also must set OFF time.
So program1 ON is set, then program1 OFF is set
Each ON is set for day, hour and minute
Each OFF is set for day, hour and minute (select same days for OFF and that you chose for ON)
For example if you want timer to turn ON all days MO-SU, make sure OFF time is also set for all days MO-SU.
Program the timer:
Set ON
Press arrow? until display shows PROG 1 ON
This is program1 ON.
Press SET button, but do not press and hold set button as you did when setting current time.
The days for program1 ON will be flashing on display.
Press ? ? to select day, or groups of days that you want for program1 ON.
Press SET button again, and program1 ON hour will start flashing
Press ? ? to select hour that you want for program1 ON.
Press SET button again, and program1 ON minute will start flashing
Press ? ? to select minute that you want for program1 ON.
program1 ON is set, next you must set program1 OFF
OFF
Press arrow? until display shows PROG 1 OFF
This is program1 OFF.
The days for program1 OFF will be flashing on display.
Press ? ? to select day, or groups of days that you want for program1 OFF.
Press SET button again, and program1 OFF hour will start flashing
Press ? ? to select hour that you want for program1 OFF.
Press SET button again, and program1 OFF minute will start flashing
Press ? ? to select minute that you want for program1 OFF.
program1 ON and OFF are set, next you will set program2 ON by repeating steps above.
If you do not want to set more programs, that is fine.
Timer lets you set up to 20 programs.
Finish programming: when program ON-OFFs are set, press TIME button and current time displays.
Last step:
Push manual override button until AUTO is displayed. This will let timer turn lights on and off.
Plug lamp into timer.
Lamp must be turned ON.
Plug timer into wall.
This is much easier than the paper you got with it!
Thanks a bunch
The question marks are arrows. For some reason the fixya format changes character-map arrows into question marks.
Great, well demonstrated the settings. thanks
There are lots ofhttp://addprinterwindows10.com reason for the prefer it. Just leave the narrow type of the option and you can create the many of the works by it, because it has the various option for the add printer wizard windows 10.
Good
Red that is explicitly for the weddings the mark shade of the ladies that makes them look all the more beautiful and exquisite. We should wear this online assignment of astounding hues on capacities and occasions with the end goal to look all the more lovely.
The basic part of the magnetostrictive all kinds of sensor is the sensing element called the waveguide. The waveguide is made of ferromagnetic materials such as iron, nickel, cobalt and their alloys. The position magnet which is round in shape moves around this waveguide.
Initially when position has to be determined the Nagano keiki Pressure sensor electronics sends a current pulse called the interrogation pulse through the waveguide and starts the timer abs speed sensor . So a magnetic field is created around the waveguide. When the magnetic field of the position magnet interacts with the magnetic file around the waveguide a strain pulse is generated which travels at the speed of mazda 6 suction control valve on both sides. On one side this strain pulse is detected by the strain pulse detection system and then processed by the electronics and converted into electrical pulse suction control valve . The position is determined based on the time the strain pulse takes to Speed Sensor reach the strain pulse detection system. The un useful pulse which travels opposite Pressure Sensor the electronics is damped by damping module to prevent any interference by reflections from the waveguide tip.
Common Rail Pressure Sensor
Temperature Sensor
Fuel Metering Valve
Diesel Solenoid Valves
Gnld things
10 Amazing benefits of honey
