2006 gmc envoy Denali 4wd will not engage
This vehicle had option of three different transfer case ! Which one of these is the one in your vehicle ?
Transfer Case - NVG 120-NR9 Transfer Case - NVG 126-NP4 Transfer Case - NVG 226-NP8
The New Venture Gear model NVG 226 RPO NP8 transfer case is a two speed automatic, active, transfer case. The NVG 226 provides five modes, Auto 4WD, 4 HI, 4 LO, 2 HI and Neutral. The Auto 4WD position allows the capability of an active transfer case, which provides the benefits of on-demand torque biasing wet clutch and easy vehicle tuning through software calibrations. The software calibrations allow more features such as flexible adapt ready position and clutch preload torque levels. The technology allows for vehicle speed dependent clutch torque levels to enhance the performance of the system. For example, the system is calibrated to provide 0-5 lb ft of clutch torque during low speed, low engine torque operation, and predetermined higher torque for 32 km/h (20 mph) and greater. This prevents crow-hop and binding at low speeds and provides higher torque biases at higher vehicle speeds, to enhance stability.
The New Venture Gear model NVG 126 RPO NP4 transfer case is a one speed automatic, active, transfer case. The NVG 126 provides only one mode, Auto 4WD, and is transparent to the operator. The active transfer case provides the benefits of on-demand torque biasing, wet clutch and easy vehicle tuning through software calibrations. The software calibrations allow more features, such as flexible adapt ready position and clutch pre-load torque levels. The technology allows for vehicle speed dependent clutch torque levels to enhance the performance of the system. For example, the system is calibrated to provide 0-7 N?·m (0-62 lb in) of clutch torque during low speed, low engine torque operation, and predetermined higher torque for 32 km/h (20 mph) and greater. This prevents crow-hop and binding at low speeds, and provides higher torque biases at higher vehicle speeds, to enhance stability
The New Venture Gear (NVG) model NV120, RPO NR9 transfer case is a single speed, full-time, all wheel drive (AWD), transfer case that incorporates a front/rear drive differential carrier assembly.
