I You reload myproxim_ap_4000_mr lr and show me that I destroyed Software router I can not only use a scan tool Port lan shines sporadically How can I fix it
In order to get your router back to the original settings, you must push
in the reset button (usually on the back of the router) for somewhere
between 10 and 30 seconds depending on the router. You may need a pin or
something small to push in the button, because it can be recessed. Once
you have reset the router, the username and password will be changed to
the defaults, admin and password, respectively. One thing you must
remember is that resetting the router will change all of the router
settings back to the factory settings. This means you will lose all of
the changes you made since you got the router. Make sure to write down
any things you've changed, so you can change them back after the reset.
Also, I recommend updating to the latest firmware after the reset.
If you need more help post back!
Thumbs and testimonial are welcome!
There a great article at General Router Setup. If you need more help post back! Thumbs and testimonial are welcome!
Hi There, Can you check the adapter or replace with other adapter that has same specification ( Voltage and Ampere) , usually this cause of bad adapter.
See the AP700 Hardware Overview below.... while the router is on.. press and hold the reset button (hole) for about 10 sec, using a paperclip.. the simplest way to restore your default setting..
default ip is 169.254.128.132 sub mask 255.255.0.0, but yes if you are going with a router then look for an ip that is assigned by the routher dhcp settings.
The software you need is available free at Proxim, the legal copyright holder of the software. You will need to make a free account to download the software. Here is the download link: http://support.proxim.com/cgi-bin/proxim.cfg/php/enduser/std_adp.php?p_faqid=1225
Simple solution, firstly do not press the reset button to long as it will erase all software, or you will have to do this the hard way. google the software called ScanTool run that from either ethernet or wireless, this tool shows you the AP-700's ip, mac, and name (some techs run these AP's coadjacent so it shows the name as well). You can change the ip of the AP-700 from here most of the time with the proper pass, then you should be able to connect to it regardless. if this dont help ... Proxim/Support/AP700 you will find more of an in depth approach of these things there.
Device setting themselves on their own to default? Sometimes power surges, thunderstorms causes all of these. Reconfigure devices and try to buy surge protector.
