Question about Lenovo ThinkPad X200 Notebook
X200 tablet power on troubles hello i havve a x200 and when i turn it on nouthing appears on screen stays black as iff it was never turned on power on lights appear u can hear pc quietly powerd on but no screen and the sgb video port with an external monitor does not work either help me please its driven me [email protected]
Posted by chacesummey on
Simon Jarslev
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    New Friend:
  • 102 Answers
Try go into BIOS (press F1 after you start the pc). Then F9 for resetting BIOS settings.
Posted on Sep 06, 2019
5 Related Answers
Anonymous
SOURCE: laptop fan spin for 2 second and display not show
i change my motherboard cell and now my laptop running very well
Posted on Feb 10, 2010
SOURCE: broken screen, external monitor via VGA won't
please call the tech support line 1-800-426-7378 for immediate pc repair
Posted on May 11, 2010
dennis bullard
  • 4090 Answers
SOURCE: How to take a video image using the integrated
That's because Fujitsu has specific software that is written to take advantage of its own built in camera
Please rate my help++++Thanks for using FIXYA
Posted on Jun 03, 2010
Anonymous
  • 31 Answers
SOURCE: Thinkpad X200 display problem. LCD backlight kept
try to check your video card..
Posted on Oct 17, 2010
elix0411
Jose Cada
  • 3530 Answers
SOURCE: I have a Lenovo ideapad
Welcome to Fixya
THis means that the bootmanager is corrupted. You can still use the computer by pressing the One key recovery button. Look for the button located beside the power button that has a U-turn sign icon. Press that button once whn the computer is turned off. This will restore the computer back to factory defaults. Please take not that this will delete all files and data inside the computer.
Thank you for using Fixya!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Posted on Dec 19, 2010
Hello, I have a tablet that when I turn it on the screen stays black. What can I do to fix that?
Has it been fully charged? Try to reset it by pressing the green/and or amber light 40 seconds and then press it again and see if it fixes this.
Jun 19, 2017 | Tablets & eReaders
I charged my tablet and turned it off for a few hours and now it wont cut on
Press and hold power button for a few seconds.. To run safe mode.
This is a common problem caused by power fluctuations.
Nov 12, 2015 | Tablets & eReaders
My tablet wont turn on unless connected to a power supply and when its connected the screen stays black
I'd check the tablets internal battery and also the cord and plug from the charger. Though the cord powers it enough to run the connection may be too insufficient to -keep- the battery charging. I would also turn the device completely off while troubleshooting.
Jun 27, 2015 | Tablets & eReaders
Help to reboot my tablet
Hi, you need to perform a factory reset, follow these instructions:
  1. Turn tablet off. You may need to use two hands in this process to press and hold buttons properly.
  2. Turn on the tablet with power button, wait a full 2 seconds from the time the tablet starts showing the red Motorola logo, then press and hold the down Volume key. (you should not hold down the power button after it turns on and logo appears)
  3. "Android Recovery" will appear on top of screen if timing is done correctly. Release volume button. (if you continue to press volume down at that message, the message will cycle through "RSD, Fastboot, and back to Android Recovery. Make sure message states Android Recovery before you go to next step). If stuck at a RSD protocol or Fast boot screen, reboot the tablet by holding power button then pressing the volume up).
  4. While screen states "Android Recovery", Press volume up button, the screen will say "Entering Android recovery mode" and a few seconds later an Android robot graphic will appear alone on the screen. Release buttons.
  5. Hold down power button and then press the volume up key together to see the Android Recovery screen menu selections.
  6. Use the volume buttons to move up and down through selection in this menu.
  7. Using the volume down button, scroll down to "Wipe data/factory reset"
  8. Tap Power hard key to select option.
  9. Scroll down to select "Yes, delete all user data".
  10. Tap the power button to select. Wiping and formatting data will take a few minutes.
  11. You will return back to the Android recovery screen menu.
  12. Tap the Power button to "Reboot system now" which will power-cycle tablet and eventually power back on to the Initial Set-up / Welcome screen present when you first turned on your tablet.
Dec 31, 2014 | Tablets & eReaders
Trio 10 1 turns on but wont go past the next screen to see my apps
Press power and volume + buttons together until reset screen comes on, then select factory reset!
Nov 09, 2014 | Mach Speed TRIO Stealth G2 10.1" 16 GB...
Why wont my skypad alpha 2 turn on
Hello, My SKYTEX Device (Tablet) I've had mine for about two weeks so far, well recently my SKYTEX device has been acting I don't know why?!
This morning I wanted to get into my tablet, I couldn't because it's NOT working, what it is, I'll be charging it, and thinking it turned off, I don't know why, my screen just stays black, and any advice how I do reset it as it was NEW from a computer?
Thank!
Jan 19, 2013 | Skytex Skypad Alpha 2 Android Tablet Kit
How do i get to windows boot manager
Step 1 Turn on your computer.
Step 2 Press the space bar on the keyboard immediately after the BIOS screen appears and before the Windows logo screen appears. Press "F8" to access the boot options.
Step 3 Select an operating system to boot and press "Enter."
Jan 29, 2018 | Lenovo ThinkPad X200 Tablet PC
My laptop used to work fine. the other day i went to turn it on. The screen stayed black and all the lights around and including the power light started flashing randomly
hello i recomend that you replace your battery ,try connect the charger without the battery installed iff this fails problem could be internal on the bios will need to be rebooted ,
Mar 25, 2011 | Acer Aspire 1640Z Notebook
It no longer turns on and boots up
If after powering it on there is black screen and green light is flashing (the one for wireless/bluetooh) probably there is something wrong with the motherboard. If the laptop starts up to a moment when messages on a screen appear it means that all various components may malfunction (such as RAM memory, Hard Drive, graphic card, etc) .
Jun 17, 2008 | Acer TravelMate C110 Tablet PC
Lenovo ThinkPad X200 Notebook Logo
153 people viewed this question
Top Lenovo Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
efs_perpends
efs_perpends
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
