Hitachi 53SWX10B 53" Rear Projection Television Logo
Posted on Dec 04, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I HAVE A HITACHI 53WX10B TV AND THE SCREEN IS BLURRED. I HAVE TRIED THE MAGIC FOCUS BUTTON AND THE SHARPNESS BUTTON. ANY OTHER IDEAS?
Chi Chu
Level 3:
  • Hitachi Master 8,457 Answers
  • Posted on Dec 04, 2010
Chi Chu
Hitachi Master
Level 3:
Answers
8457
Questions
0
Helped
2822841
Points
26282
Magic focus button don't work or datas never reaches 100%.Tv have a problems,known as a convergence problems,it dead.Tv have colors lines R,G,B mis alingments,have colors shadows pictures or a 3D pictures look alike?The tv have a dead convergence board.The tv convergence board have 2 STK convergence ICS and some or all of it resistors are dead too.These parts on the tv convergence board,must be replaced to solved the tv convergence pictures problems.The shop,will cost like $300-350 for parts and labors.
1helpful
Magic focus/convergence/blurred double images
Try to get an electricians help or contact a TV repair specialist.
2answers
We cannot get the color to align. It appears like there is a blue or yellow background around words
If your TV looks 3D, warped, or distorted it likely has a convergenge problem.
If however it just looks dull, washed out, redish, greenish, or blueish or if it looks like objects on the screen have halos the fluid in the lens has soured.
You can search google for parts or you can get the parts with repair instructions from sites such as www.TvRepairKits.com
2answers
Hitachi 43fwx20b Convergence Problems
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Have an Hitachi 51swx20b. The colors are not aligned and magic focus will not work. Vertical and sharpness is grayed out...
Ur convergence it dead.U know how to solders?Buy a convergence kit to replaced parts.Websites Tv repair World.com Tvrepairkits.com.
2helpful
2answers
The picture is blurred, words are blurred . . overlaid with red. Tried Magic Focus after 20 minutes and it was no better
you need to change the convergence chips that are attached to a heat sink, they are the two black chips with a lot of legs on them.
Not focused
Please! Stop using the magic focus now!
There are internal parts that have failed and this requires attention by qualified personnel.
The more you hit the magic focus, the more the proper calibration points will go off the mark, since the computer only knows that the calibration is incorrect, but is unaware that the parts that DO the calibrating are defective.
Sometimes this will make the repair more difficult, since a major maual recalibration may be necessary if the registers "rolled over".
If no one had touched the magic focus and just called for repair, the set would just need the parts. Once replaced, the set would look normal. Yours will require a few more steps.
www.mcveyelectronics.com
Yellow and blue color ruins total picture on 50" tv,can't get rid
lupe0112,
I'm no expert, but I think that you have a problem with the convergence of the 3 color guns. I've been working on a similar problem. As a first step, have you tried "Magic Focus?" The Magic Focus button for the Hitachi 53UDX10B is at the left of the small front panel controls that also include your RCA composite and SVideo connectors. Let the set warm up for about 20 minutes (as recommended by the user guide), and then press the Magic Focus button. When you press the Magic focus button, the set will auto align the 3 color guns. If this doesn't fix your problem, unplug the TV for at least 4 hours and try again.
Hitachi 61udx10b
Replace Both of your STK ICs they are your convergence ics they are big black ICs will have Part# on them for example STK392-110, if they are 110s use 180s, if 020s use 040s other wise replace with exact same number. To get Parts call Electronix 1-800-223-3205
2answers
Blurred picture
try the focus adjustment knob on the back of the flyback transformer....if that does not work...order a focus block
Top Hitachi Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
