Question about Logitech Z-2300 2.1 Computer Speaker System (3-Piece)
Wired remote female connection
The port where the wired remote plugs into the subwoofer is causing the speaker on the right to not work. I am fairly sure that it is a pin inside the female connector that has been somehow damaged. I am able to temporarily fix it so that the speaker works by wiggling and reconnecting (many many many times) the wired remote input into the sub, but i usually have to do this several times a day (which is somewhat of a hassle and probably not doing any good to the sub). I have looked all over for replacement parts or for ways to fix this and havent found anything useful. Any suggestions to help me are very much appreciated.
PS: i have misplaced my warranty
Posted by ReiJi on
5 Related Answers
Anonymous
  • 25 Answers
SOURCE: Broken D-sub cable
I would advise against a direct solder inside the unit. I would go and purchase a replacement connector from a Radio Shack or other electronics parts store. Solder wires to this, then plug in, should fix problem.
Posted on Apr 30, 2008
Anonymous
SOURCE: Service Manual for X-230
I used a Radio Shack D-Sub 9 Pin Connector #276-1427
Pin 1-Empty Pin 2-Purple Pin3-Yellow Pin4-Red Pin5-Shield Wire & Green
Pin6 & Pin7-Gray Pin8-Blue & Black Pin9-Brown
The pin numbers are on the face of the connector and are hard to see.
Posted on Jan 06, 2009
Open SKy
Carlos L. Burgos
  • 620 Answers
SOURCE: Very Quiet Subwoofer - amplifyer problem?
Yes, it is fixeable, but you can carefully check this,
1) open the SUB, and see if any cable is broke or loose in the negative and positive poles.
2) check if there a loose cable on the terminals point of attach speakers.
3) other than this is a defective AMP inside and mus be change.
open sky
Posted on Mar 22, 2009
Anonymous
SOURCE: I need a circuit diagram for My Logitech Z-640 Computer Speakers
You may have to call Logitech support or email to find out what the pin out is. that would be my only solution if there is one.
Posted on Apr 24, 2009
Anonymous
  • 3 Answers
SOURCE: Logitech THX Z-2300 only one speaker works
try tapping the speaker box in your palm while the speaker is connected. There might be a bad contact of the wires inside. I had to open up my speaker to find that out. i moved around the wires connected to the cone of the speaker and then started to hear music once i did that. it was the left speaker by the way.
Posted on Mar 09, 2010
Here's my delema...........I have a Pioneer subwoofer HTP102-SW and want to conect to my Pioneer AC receiver. Subwoofer has 8 speaker ports (L+R output & L+R input). Do the speakers connect to the...
The left and right outputs from the receiver go to the left and right inputs on the subwoofer and then you wire the left and right speakers to the left and right outputs on the subwoofer....it is sort of what we calll daisy chained
Dec 30, 2010 | Pioneer Televison & Video
How do i connect the boston BA745 comp. speakers to my gateway desktop?
Assuming you have the BA745 2.1 speaker set up, all of the cables connect to the subwoofer and then to the computer or the satellite speakers (these are built into the speakers IIRC). Take the cable with the black box (2 pins) to red and green. The red and green plugs go into the matching color ports on the computer and the pins on the black end fit into the jacks between the those for the two satellites. Plug the single end speaker cable into the subwoofer port all the way to the right on the back of the subwoofer. Plug the wire with the two plugs into the matching color jacks (blue to the left, red to the right). Then plug in the power adapter cable in the farthest left jack and plug in the other end to a surge protected power strip (that is plugged in and turned on).
Oct 24, 2010 | Boston Acoustics BA745 Computer Speakers
My philips dvd player 5.1 have female ports at back side for audio but i have the sound system of LG which has simple naked wire to connect .
Philips DVP 3256 has 6 outputs which takes in RCA connectors
Altec lansing VS3251 has 3 STEREO outputs.
Buy 3 nos of STEREO (female) to RCA (male) cables
1. Connect the Altec's green wire to first stereo-to-RCA cable. RCA ends to DVP 3256's Front left and Front right
2. Connect the Altec's black wire to second stereo-to-RCA cable. RCA ends to DVP 3256's Rear left and Rear right
3. Connect the Altec's orange wire to third stereo-to-RCA cable. RCA ends to DVP 3256's Centre/Sub woofer. Interchange RCA ends if the Subwoofer sounds dull.
Good Luck
Jan 29, 2009 | Altec Lansing VS3251 Speaker
Speaker wire to coaxial cable
Yes ! all you have to do is go to radio shack and tell them you want a coaxil to RCA adapter (screw coaxial into wallplate and plug RCA end into sub and your all set!)
Please rate answers and help keep this site FREE!
Thank You
Dec 28, 2008 | JVC SP-PW100 Subwoofer
Buzzing sound from woofer when I plug in
If the woofer works fine when plugged into any other port, I would say that you have a connector on the receiver that has a loose connection or possibly a cold solder joint (poor or broken solder joint). RCA jacks can be stressed quite a lot especially if you use cables that have very tight connectors. The female RCA jack gets wiggled or twisted when trying to remove a cable and this causes solder joints to crack. I would have a look at that connector on the receiver..
Mar 02, 2017 | Panasonic CT-35SF23 35" TV
Replacement Kenwood KSC-WA82RC Car Subwoofer remote control wire
It looks like the S-video you need one end to be male and the other is female end.The high quality the S-video wire the better the sound.Make sure you get a long enough cord. Take it with you to radio shack or and car audio or home audio find the female end of the S-Video and it should plug in perfect.Wire it up and enjoy some tunes
Oct 16, 2008 | Kenwood KSC-WA82RC Car Subwoofer
What Is the Blue Input Port on the Back of the AOpen Subwoofer?
It is a proprietary controller that plugs in to that port. Kind of a wired remote, that controls on/off, subwoofer volume, and speaker volume.
Aug 17, 2008 | AOpen MS-810 Computer Speakers
No remote from Cd player. What to do?
thats a car dvd player right what u would do is to take the back of the unit and look for the female ends of rca's on the unit that they will say rear out put hook them up and run them to the amp and i dont get what u mean about the remote wire but let me no if that helps
Apr 04, 2008 | Jensen A600HLX Car Audio Amplifier
Need wiring and 9pin connector diagram
Dell (Altec Lansing) A425 Subwoofer Pinouts
This is a standard female DB-9 serial port.
Here are the pinouts.
Pin 1 = Left Speaker Out +
Pin 2 = Left Speaker Out - (Common Ground)
Pin 3 = Left Line In +
Pin 4 = Right Line In +
Pin 5 = Left/Right line In - (Common Ground)
Pin 6 = Right Speaker Out +
Pin 7 = Right Speaker Out - (Common Ground)
Pin 8 = Power A
Pin 9 = Power B
Jumper (short) Power A to B to turn on.
If you want a volume control you need to put one on the inputs. You will buy buy a stereo volume control or potentiometer.
Here is some info on how to do this.
http://g4tv.com/screensavers/features/43665/Pump-Up-The-Volume.html
Cheers!
Mar 27, 2008 | Altec Lansing ADA425 3-piece 30-watt...
Subwoofer
Most AV receivers do not have a built in amplifier block to drive a subwoofer, and merely provide the subwoofer output channel at line voltage. Thus, a powered subwoofer is required. Does the subwoofer require mains power? From your description, I'm guessing it doesn't. If not, it does not have a buit in amplifier, you will need to purchase a monoblock amplifier, which is just a mono amplifier with a volume control, no tone controls or anything else. Make sure that the amplifier power rating is as close as possible to the subwoofer power rating, as it is quite possible to blow a speaker by using an amplifier whose power output is too low, by overdriving the amplifier , and putting DC through the voice coil when the amplifier clips. If it does require mains power, it will have an amplifier built in, but does not have line level inputs.
Sep 14, 2007 | Polk Audio CSi40 Center Speaker
Logitech Z-2300 2.1 Computer Speaker System (3-Piece) Logo
Top Logitech Audio Players & Recorders Experts
Vernon Taylor
Lawrence Oravetz
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
