Question about Marshall Amplification Marshall IBS Bass Amp Knobs (Pkg 5)
Does anyone know how to make a bass knob remote out of phone line? What the color code? I have 4 different color wire here but i don't know what to do to make a bass knob remote.
Fred Yearian
  • Marshall Amp... Master
  • 5,603 Answers
It is NOT clear what you are trying to do... HOWEVER if you are attempting to extend a bass potentiometer remotely, you CANNOT use the four wire flat telephone line as it is unshielded and you will pick up hum.
Posted on Dec 04, 2010
Testimonial: "thanks... lucky i haven't done it yet.."
My ibanez sr700 bass guitar's volume knob is very
To remove the knob, there should be a small hex key or allen screw on the side of the knob. Just loosen the screw. You don't have to remove it.
To tighten the nut properly, you may have to remove the back panel of the bass and hold the potentiometer from the other side. If allowed to turn too much, it could mess up the wiring.
Feb 26, 2013 | Music
My bass makes no sound.
check the jack wiring, or the battery clip integrity- sometimes the clip wires break but they look fine.
Dec 16, 2012 | Schecter Omen EXtreme-4 BCH
Buzz on treble tone knob?
Tone pot should only have 2 of the 3 lugs with connections, one of which should go to ground or to the capacitor that goes to ground. If by "double wire" you mean shielded cable, the outer 'wire' is the shield that should be grounded at one end at least, probably to the back of tone pot.
May 09, 2017 | Music
Line 6 Spider III 15W- My Bass and Drive knobs arnt working... my mid and treble seems to be fine plus all my channels and effects but just those two knobs...and its buggin the **** out of me.... any...
resolder the three legs of the pots back down to the pcb. usually the treble feeds the bass, then from bass to mid then to ground. so if treble and mid are working its hard to imagine why the bass wouldnt be working. i would try to resolder, as you might have cold solder joints. keep it unplugged, pull off the knobs, open it up, remove the pcb screws and pull/flip out the pcb and resolder all of the pots.
May 25, 2010 | Line 6 Spider Iii 15 Modeling Guitar...
Would like diagram of the control knob functions have 4
heres the schematic for your bass.
http://www.schecterguitars.com/schematic/schecter_STILETTO_DELUXE_4&5_OMEN%20458.pdf
hope this helps.
if ive helped you please rate
Feb 13, 2010 | Schecter Stiletto Deluxe-4 Bass
Bass Guitar Keeps sound keeps cutting in and out.
There is an inconsistency in your text. You indicate that cables were swapped and problem still existed...
You said:... "i have tried using it on a different amp and still fine".
If you tried it on a different amp and it was still fine then the guitar is probably OK.
THEN your amplifier is in question as the root of your problem.
What is the amp you have? The guitar is the CB-42, but what amp do you have?
MANY intermittent problems with amplifiers are often with the input jack itself. These jacks are easily broken by tripping over a cable plugged into them.
Jan 04, 2010 | Fender Rumble 100 Bass Guitar Amplifier
I nd to find parts for my bass
its a dean custom zone active bass get the parts off the dean site
Oct 24, 2009 | Music
Wiring schematic for YahamaR2X200F fretless bass
http://www.sonfatherguitars.com/Schematics/P-Bass.GIF
this is a seymore duncan wiring diagram. its standard bass wiring, and by the looks of the picture it should be close. luckily, most electrical manufacturers use universal wiring color codes.
yostamplifier.com
Mar 25, 2009 | Yamaha BB414 Bass Guitar
Marshall Amplification Marshall IBS Bass Amp Knobs (Pkg 5) Logo
228 people viewed this question
Top Marshall Amplification Music Experts
matt martin
matt martin
rhodesworks
Are you a Marshall Amplification Music Expert? Answer questions, earn points and help others
