Question about Whirlpool DU1010XTX Builtin Dishwasher
Model du1010xtxq1 will not drain? - Whirlpool DU1010XTX Builtin Dishwasher
Posted by oldfomoco on
Daniel Scott
  • 4,323 Answers
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Posted on Dec 04, 2010
Kitchen aid dishwasher m # kdfe304dss wont drain , can hear clicking sound from underneith.what do you recommend? 14 months old.
KitchenAid Dishwasher Not Draining - Model KUDP02CRBL0
www.repairclinic.com/RepairHelp/...Dishwasher/...-/KitchenAid-Dishwas...
See All Dishwasher Parts for model KUDP02CRBL0. Cause 1 Drain ... If the drain pump motor is not working, the dishwasher won't drain. To determine if the ...
How to repair a dishwasher, not draining - troubleshoot ...? 6:18https://www.youtube.com/watch?v=rO19zoOyNHAFeb 26, 2014 - Uploaded by AdamDIYMost of the time if it is not draining, the garbage disposal is clogged or there ... If you have a newer model dishwasher that looks different from the one .... But with the help of your video, I was able to show her where her ... How to Fix a Dishwasher thatWill Not Drain : How to repair your home - Duration: 1:50.Missing: kdfe304dssDishwasher Repair-Will Not Drain-Part 2 - YouTube? 4:14https://www.youtube.com/watch?v=dYHTdzQrsBAApr 20, 2013 - Uploaded by Frosty LifeInstructions 1 Press the "Cancel/Drain" button on yourKitchenAid dishwasher after the Clean light comes on to manually drain the standing ...Missing: m ‎kdfe304dssReviews on kitchenaid dishwasher kdfe304dss
Jan 17, 2016 | KitchenAid Dishwashers
My Amana portable air conditioner Model ACB08Ke is not draining properly
make sure there is a trap on drain line will not drain properly without it.
Aug 03, 2014 | Amana Heating & Cooling
How to replace fork seals 2007 fatboy
To replace the front fork oil first support the motorcycle so the front end is off the floor and the forks are fully extended. Remember that the FLSTC and FLSTF models have a preloaded fork spring and that the fork tube plug is under spring pressure.Then you remove the fork tube caps. And then you drain the fork oil. ON FXSTD models, your remove the drain screws and washers from each fork and drain the fork oil this way. ON ALL MODELS EXCEPT the FXSTD, remove and discard the drain screws and washers from each fork and drain the fork oil and then you install new drain screws and washers. ON FXSTD models, apply LOCTITE THREADLOCKER 243 (blue) to the drain screws and tighten them to 12-18 inlbs (1.4-2.0 Nm). ON ALL MODELS EXCEPT FXSTD, tighten the drain screws to 52-78 in-lbs (5.9-8.9 Nm).THEN fill the fork with Harley-Davidson TYPE E FORK OIL (Part No. HD-99884-80).Either by installing oz or cc's of fluid if the forks were left in the frame or by measuring the amount of oil in the tubes in inches or mm if the forks were removed from the frame and disassembled. In the latter case the oil level is measured from the top of the fork tube with the spring removed and the fork fully compressed.
MODELs FLSTC, FLSTN use 13.4 OZ 395 cc4.41 inches 112.0 mm
MODEL FLSTF uses 13.4 OZ 397 cc5.04 inches128.0 mm
MODELs FXST, FXSTB, FXSTC use 12.5 OZ370 cc 6.69 inches170.0 mm
MODEL FXSTD uses 11.6 OZ343 cc 7.48 inches190.0 mm
FINALLY tighten the fork tube caps to 40-60 ft-lbs (54.2-81.3 Nm).
Jul 10, 2014 | 1993 Harley Davidson FLSTF Fat boy
Water will not drain.
If you hear the pump operating during the drain cycle but water is not draining then check for blockages in the filter, drain hose and kitchen drain including inskincerator. If you have done all this and no success then the problem is inside the tub sump. Check the drain pump Item 60 in this diagram
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Dishwasher-Parts/Model-58714153400/0582/0130000/R0408023/00004?blt=06&prst=&shdMod=
You can see a youtube on this topic http://www.youtube.com/watch?v=ZMPXn6XgRkk
Apr 19, 2014 | Kenmore Dishwashers
How to change oil
There is a drain plug located on the lower side of engine somewhere....it varies from model to model. Simply take out drain plug....drain oil in approved container......replace oil filter( if your model has one) with a new one....lubing the oil filter seal before installing....replacing drain plug....and adding the correct amount and type oil for your model engine. Always return used oil to a recycling center...auto part store usually provide this service.
Apr 01, 2014 | Briggs & Stratton Garden
Bosch shu43c02uc
test this steps and fix it. God bless you
Belt, Water Pump
Although few dishwashers have a water pump belt, if the dishwasher won't drain there might be a worn or broken water pump belt. After removing the lower kick panel the motor can be seen in the front, the water pump belt is on the bottom of the motor.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Drain Pump
If the dishwasher won't drain, the drain pump might be defective. Test the pump motor with an Ohm meter. Drain pumps are not repairable, if it's defective it will need to be replaced.
Drain Impeller
The drain impeller is attached to the pump and pushes the water out of the dishwasher, through the drain tube and into the garbage disposer or drain line. If the dishwasher won't drain, the drain impeller might be broken or worn out. Replace both the impeller and seal at the same time.
Drain Solenoid Kit
If the dishwasher won't drain, the drain solenoid kit might need to be replaced. The drain solenoid is an actuator that opens a flap to allow the water to drain.
Drain Valve
The drain valve can get clogged with debris and should be cleaned out if the dishwasher won't drain. If it seems clear of debris but won't actuate, it will need to be replaced. The drain valve is not repairable.
Pump and Motor Assembly
If the dishwasher won't drain, the pump and motor assembly might be defective. If the motor runs during the drain cycle, check for a blockage in the drain line. If the motor won't run during the drain cycle or if it just hums when it should be running, the pump and motor assembly might need to be replaced.
Clogged or Improperly Installed Garbage Disposer
If the dishwasher won't drain and the garbage disposer was installed recently, the installer might have forgotten to knock out the drain plug from this disposer. All garbage disposers are sold with a solid plug in the drain tube for situations where a dishwasher isn't connected. However, if the dishwasher is connected, the plug will need to be removed. If the disposer wasn't replaced recently, remove the dishwasher drain hose from the disposer and clean out both the fitting on the disposer and the end of the drain hose. These are the most common places to find an obstruction if the dishwasher won't drain.
Drain Hose
If the dishwasher won't drain the drain hose might be clogged. Remove the drain hose from both the dishwasher and the sink drain to clean it out. The most common place for an obstruction is at the garbage disposer.
Check Valve
If the dishwasher won't drain the check valve might be stuck closed. The check valve is a device which prevents water from returning to the dishwasher after it has drained. If the valve gets stuck closed, it will prevent the water from draining. The check valve is located in or at the outlet of the pump that the drain hose attaches to. Sometimes the check valve is accessed from the inside of the unit depending on the model.
Check Ball
If the dishwasher won't drain the check ball might be stuck. The check ball is a small plastic ball in the check valve which prevents water from returning to the dishwasher after it has drained. If the ball gets stuck, it will prevent the water from draining also. The check valve is the device that the drain hose is attached to on the dishwasher.
Jul 22, 2013 | Dishwashers
LEAKS WATER ON FLOOR ON LEFT BOTTOM SIDE
Hi and welcome to FixYa, I am Kelly
Your model number is missing the last 3 digits. I will be using this model number as a reference: GB9SHKXLB00
Things to check:
1. Open the fiberboard rear cover and make sure the compartment drain tube is not blocked on the end of the tube. The tube is item 37 of this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5160170 Remove any debris from the tube end.
2. Clean out the drain catch pan completely. Item 8 this link: (just forward of the compressor) http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5160170&diagram_id=28163869#d28163869 These can get really nasty. Do the best you can to visibly inspect the drain pan for cracks.
3. Check the freezer compartment drain funnel for obstructions. Item 47 this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5160170&diagram_id=28194805#d28194805 Remove any obstructions.
4. There does not appear to be a drain tube from the evaporator drain funnel area Item 20 this link: http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5160170&diagram_id=28163869#d28163869
This design appears to dump water from the bottom of the evaporator into the bottom of the freezer compartment through the compartment drain (item 47 step 3 above) for draining.
To ensure that the freezer compartment tube / drain is clear direct output air from your vacuum into the drain tube (item 37 first link) tube under the unit and have a 2nd person listen or feel for air flow up out of the freezer compartment drain. This will also float out any debris from the drain tub that may not been visible.
This should resolve your water leak. Feel free to ask any future questions.
Thanks for choosing FixYa,
Kelly
Aug 03, 2011 | Whirlpool GB9SHKXL Bottom Freezer...
GE Model gsd5330d00ww will not drain. There are no drain obstructions and I have replaced the piston gasket in the rear of the tub. What is my next step in figuring out the problem?
HI. check the following areas for fualts.
1. Air gap / Drain hoses
If there is an air gap (located in the sink, near the faucet), check to see if it is clogged. Unscrew the top cap and see if there is anything blocking inside. Note: If there is no air gap installed, the dishwasher might not drain properly.
If the drain hose is clogged, the dishwasher would not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher.
Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
2. Broken belt
Some dishwasher models use a belt to drive the pump. Replace the belt if found broken.
Note: Sometimes the belt would just come off the pump. Even though it might not be broken, it is recommended that you replace the belt, because it is probably too stretched out.
3. Pump
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
4. Drain solenoid
Some models (for example most GE dishwashers) use a drain solenoid to drain water out. Sometimes the solenoid gets stuck, preventing the water from draining out. Try to free up the solenoid. If unsuccessful, you might have to replace the pump assembly.
5. Motor
If the motor is stuck, it is sometimes possible to free it up by manually spinning the motor.
Replace the motor if defective.
6. Timer/control
Replace if defective (note: uncommon problem).
Jul 30, 2009 | Dishwashers
I have water leaking into my fridge ware is the drain hole
Hi, The drain hole on most models in behind the rear panel inside the freezer section.
Remove the panel andlocate the drain hole under the evaporator coils.
Some models need an add on drain heater kit. Please get me a model # so I can look your up and let you know if it needs a heater.
Vic
Jul 12, 2009 | Refrigerators
Whirlpool DU1010XTX Builtin Dishwasher Logo
83 people viewed this question
Top Whirlpool Dishwashers Experts
Michael Thomas
Michael Thomas
Mike
Marvin
Marvin
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
