Question about Braun 8585 Electric Shaver
I dropped my 8985 braun and it will no longer shave with the foil head on. It does work if you remove the foil. Did I loose a part?
Posted by bwiles007 on
Norman Worley
    Genius:
  • 1,273 Answers
You probably dented the foil head enough to stop the vibratory action of the blades, thus the working when the foil is removed. Braun has a replacement foil and blade kit sold at Walmart.
Posted on Dec 04, 2010
I have braun shaver 190s1 fully charged but the blades are not rotating for me to shave
One or more of the shaving heads is stuck on the blade foil. The latter is very delicate and wears. If there is a break in the foil often a metal shard intrudes into the path of the moving blades and it gets stuck. Remove the foil and turn on shaver - if it runs it is the foil that has to be replaced.
1helpful
2answers
The screen on my braun shaver has holes and needs replacement can i get new ones for it? its the one that says caution for use only with braun series 549 class 2 power unit www.braun.com it has a trimmer...
Braun 8985 replacement foil and blades is braun series 5 combi 51S foil and cutter replacement pack.
But costomer reviews in amazon.com who take braun series 3 combi 30B foil and cutter replacement pack is fits to Braun 8985 perfectly, very smooth and close shave. Shaves much better than the Braun 51S screens foil.
You consideration
http://www.amazon.com/gp/community-content-search/results/?ie=UTF8&search-alias=community-reviews&tag=best-electric-razors-20&Go.x=0&linkCode=ur2&query=braun%208985&camp=1789&Go.y=0&creative=9325&idx.asin=B001VH6F9G
1helpful
I have the Braun 360° Complete 8985 Electric Shaver, and ive learned that it is pritty much gonna keep being a money hole. Can any one suggest a self cleaning brand that is more reliable?
The self-cleaning shavers are all much more expensive to maintain than traditional non-self-cleaning shavers. Your model 8985 is not inherantly more expensive to maintain than any other self cleaning model by Braun or other brand. The cleaning solution is expensive, the cleaning machines break because of exposure to liquid, and the heads often wear out faster as well.
Because of this, I strongly suggest you buy a shaver without a self cleaning machine. Most models that do not include self cleaning machines are very easy to clean with an old toothbruh dipped in rubbing alcohol. If you liked the way the Braun shaved when it was in good condition, I would suggest the following models linked below as possibilities
http://shaveroutlet.com/shavers/foil-shavers/braun-series-3-370-men-s-shaver.html
http://shaveroutlet.com/shavers/foil-shavers/braun-1775-series-1-shaver-p-123.html
1helpful
2answers
Works sometimes...
Braun Model 8985
It sounds like when the foil is on, there is something causing the blade to 'lock up'. My guess is that the cutter bar between the foils may be damaged and can not move. This would lock everything up. You can check it easily. Take off the foil and turn it over. There is a plastic piece in the middle that transfers the motion of the cutter to the bar betewwn the foils. You sould be able to easily move it back and forth with your finger. If it doesnt move, you will need to replace it. You will find this item at shaveroutlet.com. See link below
http://shaveroutlet.com/braun-8000-series-360-complete-foil-and-cutter-p-143.html
If this part does not seem to be damaged, the motor brushes may be worn causing the shaver to not have enough power. Was your shaver running slowly or weakly prior to having this problem? If so, the drive unit will need replaced. You will also find this item at shaveroutlet.com. See link below
http://shaveroutlet.com/braun-8000-series-activator-motor-drive-unit-p-36.html
To install, you will first need to gently pry off the 'cap. on the bottom of the shaver that surrounds the hole where the cord plugs into to. You can use a small flat screwdriver or similar object to do this. Once it is removed, the side grips will pull away revealing 4 screws on the back. Remove screws to take off the back cover. The internal parts will then simply lift out. Reassemble in reverse order.
2answers
New head
Hello Brian, You can give the folks at www.electricshaver.com a try. They typically stock all the replacement and repair parts for most brands of electric shavers.
Here's a link to their site where you'll find part #5646768 for about $38 for a new set of the cutter head and foil (screen). It's always best to replace BOTH the foil and cutter block (head) at the same time, as any mircro burrs or nicks in the cutter blades will quickly ruin any new foil screen.
http://www.electricshaverstore.com/get_item_5646768_braun-foil-cutter-kit-360-complete-8000-series.htm
As you know, this is the simplest and easiest way to get an electric shaver back to a "like-new" shaving experience.
I hope you find this Very Helpful and best regards!
1helpful
Shaver started making a much louder buzzing sound, no longer shaves as well and now hurts a bit to use. Can this be fixed?
Hello Robert, It sounds like the foil screen might have been damaged and is causing poor shaving performance. Typically, a screen will get small holes or tears in it after providing good service for some years, however, these very thin screen foils, can get damaged other ways too.
The best way to restore the best shaving performance is to replace both the foil screen AND the cutter head block (cutter head) as it could be possible that the cutter blades have become damaged or nicked and have caused the foil screen to become damaged, as a result.
I would contact www.electricshaver.com and see if you can purchase a new set of the cutter block head and the screen foil for your particular Braun shaver model. As the Braun 360 is a tradename used on a couple of different model numbers, you really need the four (4) digit model number in order to locate the correct replacement parts.
Here's a link to their page with the various Braun replacement cutter blocks and foil screens. You might find your model number amoung them, otherwise, you can also give them a call at 1-888-476-1785 and ask them to assist you with selecting the proper replacement parts.
http://www.electricshaverstore.com/get_list_125.htm
As you are no doubt aware, replacing the cutter head and foil screen is the best and simplest way to restore an electric shaver to a like new shaving condition and much less expensive than replacing the entire shaver.
2answers
When should you change cutters &/or head?
braun series 5 combi 51S replacement screen foil and cutter block for braun 8985 replacement parts.
2answers
Where can i take my braun shaver for service? needs a foil/blade replacement
you can buy replacement cutter blocks and foils at walmart...about 50 bucks.
2answers
The blades on my Braun complete 8975 are not sharp anymore.
You replace foil cutter, that braun complete 8975 replacement foil and cutter blades is braun series 3 combi 30B foil and cutter replacement pack.
Braun 8585 Electric Shaver Logo
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Joseph Hoffmann
reference30
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
