RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
Posted on Dec 04, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Fell asleep with my rca projection tv on woke up to no picture But sound. I turned the tv off and unplugged and now when I turn it on I can here it powered up but no picture or sound. The power button blinks 5 times. Uugh!
Anonymous
Level 3:
  • RCA Master 5,138 Answers
  • Posted on Dec 04, 2010
Anonymous
RCA Master
Level 3:
Answers
5138
Questions
5
Helped
1003557
Points
13534
Look for bad capaciotrs on the deflection board cp150 2200uf 16v use 25v(,cp114,cp120) bothe 220uf 35v,cp110 220uf 200v. Deflection board is the bottom lefthand side board that has FBT flyback Transfomer on it also resolder all the Pinns on the FBT.
I fell asleep with my tv on and woke up to a blue screen, so I turned it off. Now I can't turn it back on. I tried unplugging it and still nothing. Is it over for this tv?
Depending on make and model of the TV, it may have been in the middle of a firmware update. If there is a USB input on the back, contact the manufacturer, see if you can download firmware on a USB stick, to get it going again. There may be some other way to reinitialize it the manufacturer could help you with.
I have a phillips flat screen. I fell asleep watching it one night and woke up and it was off. Ever since then when I try to turn in on it wont come on and there is a whinding noise. I have unplugged the...
This is a CRT tube tv?Yes,than high voltage is dead.The FBT-Flyback transformer is dead.Take the aparts,check the big block of plastic with a red wire with a black cap that hook to the CRT-Tv tube.U hear buzzing sound came from the FBT?Replaced the FBT-the flyback transformer should solved ur tv problems.
RCA D52W19 rear projection tv wont turn on
Try this. Change the channel of your TV to 3, do you see a picture, if not. Unplug your system for the TV. Turn off and unplug the TV. Leave it off for about 10 minutes so it can discharge. Turn back on the TV and see if it re-sets. If this does not work let me know. Give me a detailed report including any brand or models you are asking about. Hope this helps.
JimmyC
Apex Mod# GB43HD10 The picture is now blurry or wavy.
Sounds Like your convergence ICs big black ICs will part number on them example STK394-020 Call Mats for Parts on ICs 1-800-628-1118 Also Call Encompass you can order whole Board if you want to you just unplug old board and plug in new 1-800-638-3328
5helpful
The on light is blinking but there is no picture or sound.
I have the same problem with my JVC AV27750, the problem is probably the power supply relay circuit, just check and replace the 1000uf capacitor
2answers
Hitachi 60vf820 ultravision
Good Day, bgblueeyess;
Your somebody is wrong; replace the LAMP.
Good Luck, big IRISH.
Powers on by itself
TV worked FINE for the past 2 yrs---this morning we woke up and the screen is totally BLACK! No sound..nothing. REmote doesn't do anything to the TV. Red light says ON unless we unplug it. Remote won't turn off the TV.
Any advise? Picture tube??
Worked great w/out any problems until we woke up today!
Thanks,
Tina
Screen has a Green Haze to it........
1. CHECK FOR LEAKY Q6R1 (RED CRT PCB), Q6G1 (GREEN CRT PCB) AND/OR Q6B1 (BLUE CRT PCB). PART # 260P627020
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
