Connect the USB adapter into ur Laptop
After the Laptop detects the device it will look for the device driver. Cancel the setup at that point.
Go to My computer , open the external drive and click on the setup.exe icon.
It will automaticaly install all the required things.
Testimonial: "epic solution"
The Wii console is not able to connect to your wired router or modem.
1. If your connection worked previously, check to see if there is a Wii System Update that you have not aquired. To get the latest Wii System Update:
From the Wii's main menu, select the Wii icon along the bottom left of the screen.
Select "Wii Settings".
Click the left arrow to get to Wii System Settings 3
Choose "Wii System Update"
Choose "Yes" to connect to the internet and perform a Wii system update.
2. Make sure that you are using the Wii LAN Adapter made by Nintendo (click here for a picture and connection steps). LAN adapters not made by Nintendo likely will not work with the Wii console.
3. Check to make sure you are not running the Wii LAN Adapter from a USB hub (a device that connects multiple USB products through a single device), as this will likely not work. Connect the USB Connector directly to the modem or router.
4. Ensure that the Wii LAN Adapter setup is correct, and that the Wii LAN Adapter was connected with the console turned off. For step by step connection instructions, please click here.
5. Check to see if the ethernet cable you are using is not working properly, by connecting another ethernet cable from your router/modem to the Wii LAN Adapter. If the connection works using a different cable, then the problem was with the first cable.
6. If possible, try another Wii LAN Adapter. If you are unable to try another Wii LAN Adapter, or are still receiving this error code, please call 1-800-255-3700 for assistance.
For any help click here
The Linksys AE1000 Wireless USB Adapter
helps you connect your computer to a wireless network for quick Internet
access. Installing the Linksys AE1000 is fairly easy. Just follow the
steps below in setting up the Linksys AE1000 on your computer or laptop.
Minimum system requirements
- A computer with 1 GHz or faster processor.
- 512MB or more RAM.
- An available USB port.
NOTE: The Linksys AE1000 is supported for Windows 7, Vista SP1 and XP SP3 but NOT for Mac.
Step 1:
Insert the Setup CD into your CD-ROM drive.
Step 2:
Click Set up your Linksys Adapter. Proceed to Step 4.
If you do not see this, click Start on your computer and click Computer. Double-click on your CD-ROM drive. Continue to Step 3.
NOTE: For Windows XP, the file may be known as Setup.exe.
Step 3:
Read the License Agreement and click Next.
Step 4:
Insert the Wireless USB Adapter into a USB port on your computer or laptop.
Alternatively, you can also use the USB Extension Base
to connect the Wireless USB Adapter. Plug the Wireless USB Adapter into
the USB Extension Base and connect the Base to a USB port on your
computer or laptop.
Step 5:
If you have an Easy Setup key, select Yes, I have an Easy Setup Key and click Next. Proceed to Step 8.
Otherwise, select No, I don't have an Easy Setup Key and click Next. Proceed to Step 6.
NOTE: For more information on Easy Setup Key, click here.
Step 6:
Select your wireless network and click Next.
Step 7:
If prompted, enter the wireless password for your network. Proceed to Step 10.
Step 8:
Follow the on-screen instructions. Click Next once you have completed the on-screen instructions.
Step 9:
The installation is complete when you see the screen below. Click OK.
Step 10:
You are directed to the Cisco Connect screen. Click Close to exit.
