Question about Sony Cyber-shot DSC-T2 Digital Camera
How to save a picture to a memory stick,, - Sony Cyber-shot DSC-T2 Digital Camera
  • 455 Answers
Even if the Memory Stick Duo is inserted in the Camera, the images will not be saved in the Memory Stick Duo until the capacity of the Internal Memory is full. To save the images in the Internal Memory to the Memory Stick Duo, select the EXPORT option from the Viewing Menu of the Camera. Touch the MENU icon when viewing images to select the IMPORT option.
There are two option in the Viewing Menu of the Camera (Export and Import). Export option is to save from Internal Memory to Memory Stick and Import is for saving from Memory Stick to the Internal Memory.
This Camera is having 4GB of Internal Memory, hence the images captured will get saved in the Internal Memory first and then to Memory Stick once the Internal Memory is full.
Thanks for using FixYa
Posted on Dec 04, 2010
  • 222Tikka Mar 28, 2011
    So, is there any way of when you take a photo that it automatically goes straight to memory card and not to the internal memory first and having to transfer to the memory card
5 Suggested Answers
informatica
Greg Cann
  • 1114 Answers
SOURCE: accidental deletion!
First do not panic! It is possible to recover your pictures if you take care. Take the card from the camera (powered off) and if it has a "write protect" tab then lock it now. Do not try and write anything to the card or you risk causing more problems.
If you are comfortable with using a PC then you can download a FREE utility that will recover your photos from the following link:
http://www.cgsecurity.org/wiki/PhotoRec
If you need something a little more "user friendly" then you will need to buy the software. If you search the web for photo recovery software you will find many.
One I have used successfully is RescuePro that used to be bundled with some Sandisk products. Now you can get it from the link below:
http://www.lc-tech.com/software/prwindetail.html.
You can try the demo to see what you can recover before buying.
Remember - Do NOT try & write anything back to the card until you can recover your pictures to your PC safely!
Please update the question & let us know if the information given was useful to you - Good Luck!
Posted on Jul 06, 2008
Anonymous
  • 944 Answers
SOURCE: Dimage g500 not saving pictures to memory stick
Here is the link to the manual if you need it; http://ca.konicaminolta.com/support/manuals/digital_cameras/dimage-g/dimage_g500/D_G500_E.pdf page 105 describes how to set the memory priority between the stick and the camera. If this doesn't help then try formatting the stick (page 99) If still no joy then I suspect the memory stick is faulty - see if you can borrow one and try it. Hope this helps - please post again if not :)
Posted on Mar 28, 2007
Orbixx
Ricky Burgin
  • 133 Answers
SOURCE: Memory stick duo not showing pictures
It may be that you actually have the pictures stored on the camera's onboard memory and you may have to plug the camera in directly to access the pictures. Or Sony may have a strange way of accessing the files on the device (they have done the same with their MP3 players), so you may be limited to using their software to get the pictures off the camera (or memory stick).
Posted on Sep 06, 2007
Anonymous
SOURCE: How to do I transfer pictures from my internal memory to my memory stick?
You would have to click home, and then go to the memory tools and click copy. That should work.
Posted on Apr 14, 2008
welcomejee
Shahid Electronics
  • 10594 Answers
SOURCE: Pictures only save to internal memory, not memory stick...
DSC-W80 sybershot camera has facility when you insert Memory Stick in its slot, it automaticaly selects this memory card and starts saving data on it and internal memory got suspended.
Pls check memory stick 2GB and inert it correctly in memory slot in camera.
Posted on Aug 14, 2008
My dsc-w80 keeps saving all of my pics to the internal memory
Set camera on playback mode, you will see any saved picture in internal memory. Insert memory card and lcd screen will show you either blue screen if memory card has no picture files or will show you picture in memory card. That means memory card is intact with camera and ready to store fresh picture.
Set camera to camera mode and take few fresh pictures and check them in playback mode.
Let me know if you have additional question.
Thanks.
Jul 20, 2010 | Sony Cyber-shot DSC-W80 Digital Camera
How do you transfer internal memory pictures to memory card? I have a Samsung Digimax L60 camera and I forgot to put my memory card in my camera and took pictures without it in. How do i transfer the...
Put the memory stick inside the camera. Then open the photos which is save in your camera memory. Select them all & then you find a option Send to memory card or copy to memory card. Select that and press ok. Your photos transfer from camera memory to memory stick.
Thanks
Dec 30, 2009 | Samsung Digimax L60 Digital Camera
Whenever i took pictures and try to view baCK MY
Format memory stick through Format option in camera Menu.
Please note that all data on memory stick will be deleted by formatting it and memory stick will be refreshed.
Now take pictures and check does camera saves/ store.
Thanks.
Sep 28, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Not all pictures are being saved on Memory Stick
try searching the stick for other folders. sometimes the camera will create seperate folders due to res settings.
Jun 01, 2009 | Sony Cyber-shot DSC-H50 Digital Camera
I don't have a memory stick so I need to know how to save pictures to the internal memory.
You don't have to do anything. If you don't have a memory stick in the camera then all pictures will be saved to the internal memory.
May 08, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
How do i view the pictures on a psp. Ihave saved
first you have to format the memory stick in psp using the option format inside the psp and then put it in pc and then put the pics in the picture folder in the memory stick
Mar 04, 2009 | Sony PSP (Piano Black)
Aug 14, 2008 | Sony Cyber-shot DSC-W80 Digital Camera
Sep 06, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
Mar 28, 2007 | Konica Minolta DiMAGE G500 Digital Camera
Sony Cyber-shot DSC-T2 Digital Camera Logo
538 people viewed this question
Top Sony Cameras Experts
Vish Iyer
Vish Iyer
 Larry
Larry
 MikeWang
MikeWang
Are you a Sony Camera Expert? Answer questions, earn points and help others
