Question about SanDisk Sansa Fuse MP3 Player
My fuse wont charge at all. i bought a new charger and still get no charge
Posted by coltdemorris on
John Fourteen Six
  • 2,418 Answers
Make sure that the USB cable is properly plugged in and use the original cable that came with your player.
Computer in Hibernation mode
Make sure the computer isn't entering hibernation or sleep mode while the device is connected. The computer must be ON in order to charge your player.
USB Port 2.0
Make sure the player is connected to a USB 2.0 port (1.1 occasionally causes charging problems).
USB Port location
Try plugging into different USB ports (i.e. USB port in the back of the computer); occasionally the front USB ports have limited power to charge up the device.
Battery
Make sure the battery is fully charged. It takes approximately 3 hours to fully charge the battery.
Latest firmware
Depending on what Sansa player you have, make sure it's up to date with the latest Firmware.
AC charger (optional)
AC chargers (sold separately) have a 500-1000 milliamp max output, which provides much better charging ability than a USB port. These accessories are available at SanDisk web site.
Posted on Dec 04, 2010
I bought a new battery for laptop and it still wont charge
Dell uses proprietary equipment. IF the laptop wont work when plugged in and it is the original Dell charger, you need to check the charger, if the charger wont work then the battery wont charge. Note that it might be the connection on the board inside the laptop especially if the cord got pulled on while plugged into the laptop.
Oct 05, 2015 | Dell Computers & Internet
Batteries wont charge
If there is less than 10 volts on the new batteries, then use an automotive NON automatic battery charger to charge the batteries individually.
Feb 08, 2014 | Pride Health & Beauty
Kodak easyshare dx6490 charger indicator light is on but battery wont charge
Sounds to me that if you bought 2 chargers then you have a bad battery. what are the odds that you have 2 bad chargers ? Time to buy a new battery.
Jan 25, 2013 | Kodak EasyShare DX6490 Digital Camera
My PSP wont charge. I used several different chargers. I just bought it brand new and it wont charge at all. A light does not come on at all I also have a Nintendo DSI XL that wont charge either. I...
It sounds like the electrical input isn't working. Try plugging the chargers into other wall jacks. It could be that your PSP is defective, which in that case you should exchange it at the store you bought it at. Since you bought it brand new, it should still be under warranty.
Mar 22, 2011 | Sony PlayStation Portable (PSP) Console
My phone wont charge.... i have bought a new battery, charged it for 24 hours, and it still wont charge. even when it does charge it wont keep the charge for more than a day. why wont it charge. plzzzz...
It could be the charger itself that has the issue. If you have another charger try that. If you have done this and it still won't hold a charge I would contact your service provider they will try to trouble shoot issue but more than likely will get you to send phone in through warranty if your still eligible. If not eligible for warranty and don't have insurance ask about upgrade options. Hope this helped.
Apr 13, 2010 | Samsung Blackjack SGH-I607 Smartphone
My car charger wont charge it through the usb port, I just bought a new charger and the port does not recognize that anything is plugged into it.
First, I'd check the fuse in the charger plug. If that isn't what's wrong, then likely the cord is simply not compatible with your unit, regardless of what the seller says.
Jan 29, 2010 | Magellan Maestro 4250 GPS
Psp sont charge.. new battery
try a new charger if that dosnt work take it into a shop that sells them and try ask them if they no wat to do
Jun 15, 2009 | Sony PlayStation Portable (PSP) Console
Ok i just bought a new psp slim battery and a new charger and my psp wont charge and i dont know what to do but, i do have a psp slim 2001 (ice silver) and i bought a psp charger and battery thats 2000 so...
this is easy i solved it! buy a charger from gamestop that you have to take the battery out and then put it in the charger and charge it that way! that way if your fuse inside your psp is out it will charge the battey without putting it in the psp so all you do with the item is: take your battery out, put it in the alternative charger from gamestop (does not come with psp slim 2001 or 2000) plug the charger in the while charge the battery then bam!! there you go problem solved have a fun time playing your psp!
Apr 12, 2008 | Video Game Consoles & Games
Open Questions:
SanDisk Sansa Fuse  MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Jean Sintulaire
Daniel Dollive
Daniel Dollive
aliasger yq
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
