Question about Sharp Viewcam VL-A10U Camcorder
Ron but stop - Sharp Viewcam VL-A10U Camcorder
  • Marvin
    Marvin Dec 03, 2010
    Pleaase clarify the problem, what do you mean run but stop? is the battery good?
  • 2,517 Answers
HI there reset the camera and replace the battery & usde and new fully charged battery. Thanks.
Posted on Dec 03, 2010
I have craftmam leaf blower that will start and run for a few second before it dies. Once this happen it will not start again until it set over night and it then will start right up and stop again
Hey Ron,
Has this blower been sitting for a long time?? Sounds like the carb is stopped up.. there are many TINY passages that can easily stop up, take it to a qualified pro for a carb cleaning, setting, and a new spark plug.
Jul 10, 2017 | Garden
I keep eating deck belts even after replacing the pully bearings. Is there another reason? Thanks Ron
Is it the inside or the out side of the belt? This will give you a clue as to where to look for a problem.The belt path can be a little confusing. Some pulley's take the inside of the belt and others take the out side. You can get them reversed "easily" . Another thing to look for is a belt wobble stop bar on the "out feed" side of the engine pulley , if you get on the wrong side of this guide the belt will wobble and throw its self around. If you have changed the bearings then you must have inspected the pulley's for damage . Sharp edges Ect. Good luck Ron
Oct 14, 2013 | Poulan Garden
Light never stops flashing in my 36 cup farberware urn...what could be the problem/
Light tells you the coffee is ready and will stay on un till you unplug it. Ron. PS don't mind the flashing, some do and some don't.
Sep 28, 2012 | Faberware 12-55 Cup Coffee Urn
Stopped working
There are a few things that can be wrong with it, All require taking the base of off. If you want to talk with me a [email protected] Good luck. Ron
May 29, 2010 | Faberware FCP240 Coffee Maker
I have a Sears 42'' riding mower LT 2000 with 18.5 B&S engine and auto trans. When ever I cut the grass it makes a grinding sound and slows to a stop. Then I need to put it in netural and it starts to...
Ron, the trans axle is a sealed unit and not serviceable. It sounds to me like perhaps your brakes are not releasing at the trans axle. With the engine off, release the drive at the rear of the tractor and try to roll it. If it does not roll freely, your problem is with the brakes
Sep 18, 2009 | Garden
AC blowing heat and air at same time
Yeah Ron, the flap that covers the heater core is open and when you're moving the air is pushed over the heater core and into the cab your in. Possibly just a vacuum line of that controls said flap. Check all vacuum lines for good proper connection to these flaps because all of them are vacuum actuated.
May 03, 2017 | 1993 Lexus Ls 400
Mackie 1400 overload lights on
hey Ron
use a larger ground wire it will stop the overload you may have to place it somewhere new but its the size of the wire that trips the overload feature too small and amp will go and protect itself (bigger ground better sound)
hope this helped
Feb 28, 2009 | Bob Mackie Mackie M-1400i Power Amplifier...
Washer stops after wash cycle
Replace the timer.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 07, 2009 | Washing Machines
Sharp Viewcam VL-A10U Camcorder Logo
Top Sharp Video Cameras Experts
Larry Stiles
Larry Stiles
Marvin
Marvin
abdul rauf
abdul rauf
Are you a Sharp Video Camera Expert? Answer questions, earn points and help others
