SOURCE: w300 WONT TURN ON WONT CHARGE!
i happen to me you need to find a friend or a family that has the same phone that you have and that your problem solve!
SOURCE: phone wont hold a charg and wont turn on
what you have to do is to clean your phone using isoprophyl alcohol i mean you clean the main mother board then you dry it using hair dryer ,after all that try to replace the battery it has reach it death neal the cells inside they are no longer able to hold the charge.advice by dogy.
SOURCE: Battery
you have to get you charging port replaced, take the phone to a mobile service center or mobile technician close to you and have them service it for you.
SOURCE: cect i9 wont charge battery is fine
The I9 battery charger is th problem. There is a small tab on the bottom edge of the batery that allow it to clip in the phone. This tab prevents the battery from going all the way into the charger which causes a missalignment with the contacts and due to the contacts being very thin they tend to break off. If this happens you must use the USB cable to charge the phone, it plugs in under the charger. If your contacts are good you can take a thin knife and ease the tab over the edge of the plastic lip on the charger alowing the battery to seat correctly in the charger making the proper connection.
SOURCE: Motorola RAZR2 V9 new phone wont charge
Spare Battery Charger - Motorola RAZR V8 /V9 - $14.95
will need also a USA/Uk power adaptor /converter to use in Uk.100% works by charging battery separately from mobile
