Garden Logo
Anonymous Posted on Dec 03, 2010
Need a new lower guard assembly part, for an 81/4" compound Protech miter saw.model #7203
  • Anonymous Dec 09, 2010
    Looking to replace the "guard assembly" (plastic cover over the blade when saw blade is in use) for a ProTech 8 1/4 " compound miter saw, model #7203
    Harbor Freight does not carry these parts or saw brand.
  • Anonymous Mar 19, 2014
    fence
Anonymous
Level 3:
  • Master 8,197 Answers
  • Posted on Dec 20, 2010
Anonymous
Master
Level 3:
Answers
8197
Questions
7
Helped
3071312
Points
27242
Sorry the only place you can get parts for the saw is sears parts direct
Pro-Tech 8 1/4" Compound Miter Saw - Model 7203. Instructions for Pro Tech 7203 please?
Question edited for clarity 'make model (what it is)'.
Question moved from Vacuum Cleaners category.
No manual, just parts listing but all obsolete. It is old and a Sears special.
https://www.google.com/search?q=pro+tech+miter+saw+7203+manual
The 10" Model 2708 is probably close enough.
https://usermanual.wiki/Pro-Tech/7208TYPE2.3354520321/html
Sep 22, 2023 • Saws
Where can I get a plastic lower guard replacement for a 10 inch sliding compound miter saw kobalt brand?
Hello, John -
I am not finding a replacement lower guard for your model of Kobalt miter saw for sale online.
In the owner's manual for the Kobalt miter saw model SM2507LW (Kobalt is owned by Lowe's), I found the following information on the last page (page 50):
(Quote)
For replacement parts, call our customer service department at 1-888-3KOBALT (1-888-356-2258)
(End quote)
Source:
http://pdf.lowes.com/useandcareguides/000999312085_use.pdf
Note: All the parts and their part numbers are listed in the owner's manual: pages 41-48.
Therefore, I suggest you call the Kobalt Customer Service number and ask about the availability of the needed part. From the Kobalt Contact Us information, Customer Service is available Monday - Friday, 8:00 am - 5:00 pm (Eastern Time.)
Best wishes,
Dec 01, 2018 • Saws
Can i get guard for 10" miter saw
Go to www.ereplacementparts.com and search on your model to get a parts breakdown. Use TS1342L as the model number, the ZR indicates it's reconditioned. You can order parts from them or get the part numbers for the parts you need and check the internet for other vendors that may have better prices.
I can get the guard on but when lowering saw to cut the guard does not go up when lowering to cut.
Howdy, there is a slide rail on the side that has to be connected to the correct spot and unfortunately there are a few incorrect ways that look good on assembly, but don't function well. I would never Recommend Removing The Guard All Together and using safety glasses religiously, because that would be irresponsible of me, but it is the most popular action in the professional building community. Regards,
Farmerbear
My blade gaurd will not automatically rotate out of the way when lowering the blade to make a cut , Ridgid 12' compound miter saw
MS12502 has a solid arm actuation to move the blade guard, this is either bent, broken, unattached or otherwise not functional. sometimes the moving parts get full of sawdust and a major cleaning is all thats needed. generally all woodworking tools should be blown out with air after each use or end of day.
actual model number of your saw would be more helpful.
1helpful
Need to order a replacement guard for my ten inch magnum miter saw serial no 799a49347 1351
Are you talking about the lower guard if so the number is 43-54-0695 and if you will give me an idea where you are located with zip code I will try and find someone close. If you are looking for another guard please let me know and I will get that information for you
2helpful
2answers
Change blade
OK first raise the cutting head. Loosen the screw that holds the guard in place and move out of the way. Find the spindle lock on the right hand side of the gearcase and turn blade by hand (UNPLUG SAW FIRST) until it locks. With the wrench supplied with saw put it on the blade bolt and turn it clockwise to loosen, it has left hand threads, remove outer flange and blade. Let me know it you need any more help
Lower Blade Guard on a Miter saw
If you haven't fixed them yet, give me the model and brand and I will see what I can do. Dave
Top Garden Experts
Jay Finke
Jay Finke
john h
