Question about Sony Handycam DCR-TRV530 Digital Camcorder
DCR-TRV530 Digital 8 . . . Problem started with tape being caught in heads. Got a 3121 error message afterward . That stopped but in video playback mode only blue screen with play arrow at top? In recording mode szeems to be normal but can't really tell if recording cause can't play back . . . Thanks
Posted by labosta1 on
Shahid Electronics
  • 10,594 Answers
If video head got clogged then camcorder wont read tape in playback so result comes as blue screen.
Please use video head cleaning tape and clean video head of camcorder. This will solve your problem.
Video-8 head cleaning tape is available with amazon.com
Thanks.
Posted on Dec 03, 2010
When transferring (or watching) video from this Sony DCR-TRV530
Sounds video head is dirty / clogged.
Use good quality video-8 head cleaning tape for head cleaning in DCR-TRV530 and then record and playback it.
Aug 23, 2009 | Sony Handycam DCR-TRV530 Digital Camcorder
Sony DCR-TRV460 not playing back, blue screen
Follow this procedure to troubleshoot if a blue screen is displayed when attempting to playback video from the camcorder.
  1. Stop the tape.
  2. Ensure the tape has been rewound to the beginning of the video recording.
  3. Play the tape.
  4. If the issue is not resolved, stop the tape and remove it from the camcorder.
  5. Clean the video heads of the camcorder using a dry head cleaning cassette.IMPORTANT: Follow the instructions for use provided with the head cleaning cassette. It may be necessary to use the head cleaning cassette more than once per session.
  6. Reinsert the tape into the camcorder.
  7. Play the tape.
  8. If the issue is not resolved, stop the tape and remove it from the camcorder.
  9. Insert a different tape with video footage into the camcorder.
  10. Ensure the tape has been rewound to the beginning of the video recording.
  11. Play the tape.
NOTES:
  • If a blue screen is still displayed, then the camcorder may require service .
  • If the tape plays back correctly, then the first tape may be faulty or there is a problem with the video recording.
Aug 13, 2009 | Sony Handycam DCR-TRV460 Digital Camcorder
I have a blue screen during playback mode on my Sony DCR-HC32. I am not able to see anything I recorded. What should I do?
  1. Stop the tape.
  3. Play the tape.
  7. Play the tape.
  11. Play the tape.
Aug 06, 2009 | Sony Handycam DCR-HC32 Mini DV Digital...
My DCR-TRV530 Digital 8 camcorder got stuck, the tape is half way out but it does not pop-out and I can't take it out
If the tape is wrapped around a head or caught in a pinch roller, then you may be able to remove it with your pen. Underneath the tape is a small hole. Insert a pen or similar object into the hole. This will let you disengage the spindles in the tape. You have to hold the pen in the hole to keep them disengaged. You can then pull out the tape cartridge. This will let you see inside and whatever may be holding the tape in. Hope this helps.
Rob
Mar 07, 2009 | Sony Handycam DCR-TRV530 Digital Camcorder
Error code C:31:42 on a Sony Digital Handycam DCR-TRV530
Here is the solution to your problem:  C:31:42 = FG (film guide) fault during normal drum operations. Load the tape again, and perform operations from the beginning! Hope this helps.
Fotobean
Jan 19, 2009 | Sony Handycam DCR-TRV530 Digital Camcorder
Cannot view playback!!!!
First thing to determine is if your (Playback Mode) is set for Auto or Hi 8 / 8. Select VTR setting and then select Menu. Scroll to PB Mode and select Auto. Now try playback.
Oct 25, 2008 | Sony Handycam DCR-TRV820 Digital-8 Digital...
No picture during playback on LCD or TV from my Sony DCR-TRV255E
Just use good quality Video Head Cleaning Cassette. Video head is dirty/ clogged.
Feb 17, 2007 | Sony Handycam DCR-TRV255 Digital Camcorder
Playback of my 8 mm tapes on camera
Hello, there can be some contact errors at the flat cables and connectors from the mechanism to the main board. Please contact your nearest Authorized Sony Service. Best regards, Arpi
Dec 13, 2006 | Sony Handycam DCR-TRV530 Digital Camcorder
Sony Handycam DCR-TRV530 Digital Camcorder Logo
Top Sony Video Cameras Experts
Jax Planet
Jax Planet
Nasir Muhammad
Nasir Muhammad
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
