Pentax Optio A10 Digital Camera Logo
Anonymous Posted on Dec 03, 2010
Lcd screen is black when in bright sunlight,so camera usless in this situation.The rest af the time appears ok! Any ideas which may solve this problem?
  • Anonymous Dec 04, 2010
    Typrice,you are absolutely right in your description of the problem raised - thank you for putting my mind at rest, and also saving on sending away for investigation /repair that is not required.
Anonymous
Level 3:
Brigadier General:
  • Master 11,967 Answers
  • Posted on Dec 03, 2010
Anonymous
Master
Level 3:
Brigadier General:
Answers
11967
Questions
0
Helped
2197924
Points
38521
Do you mean that you can't see what's on the screen in bright sunlight? This is common on 90% of the point and shoot cameras. Only 10% have brightness controls for the lcd.
Screen
The image lcd will darken when strong sunlight or bright light.This imagen occurrence is normal in device CCDs and not constituye abnormal function.However you must determine is the LCD is faulty or normalsee the diagram attached.God bless you1_30_2013_6_52_59_pm.jpg
LCD INSTRONG SUNLIGHT DULL
You can increase the light on the LCD.
Press menu/OK, select Setup, select LCD brightness, use UP arrow to increase the light, press OK.
When taking pic in sunlight - lcd screen is whited out!!
I think that's normal. I also have experienced the same always when the screen is exposed to sunlight. Try adjusting its brightness or use an anti-glare protection.
Screen not readable in bright sunlight.
This is a problem with digital cameras with LCDs. You can make things better by upping the brightness of the screen - this will consume more power though.
Go into the menu (middle button at the back), into 'setup', and then look for 'LCD brightness'.
Dvx100a showing black screens on lcd screen and view finder
You probably have the lens cap on, the iris dial closed, or you are in vcr mode rather than camera mode. You may also have the nd filter set to 1/64th, this is only for bright sunlight. When shooting indoors with low light, set the nd filter to off and hit the iris button until iris manual appears on the lcd, then dial the iris dial in front of the iris button up or down to bring the iris to around 5.6 f stop.
AF! error
my camera comes on when I go to take a picture it comes up with !AF on the screen and will not take the picture has been working ok so its something really silly that I cannot solve.
thanking you
2answers
Horizontal pale blue lines on LCD screen and even on picture
Hey Ma-ya,
Most of the time horizontal lines are a result of taking photographs in very bright situations. If you are seeing horizontal lines on the LCD screen and in your images in low light situations this is most likely digital noise. Two ways that could fix this problem are turning the noise reduction on, and/or making sure your flash is turned on and your subject is within the range of your flash. Another cause of digital noise is having your iso set too high (I never shoot over 400 iso). I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
11helpful
Turn on camera but the lcd sceen is black
I tried all the solutions offered on the net and none worked except one. It simply said "hit the camera with the palm of your hand" (when it is on) and the screen will return. I thought, well I have nothing to lose and so I hit it on the side and sure enough the LCD is again working !!! Contacted Canon prior to this and they had no idea but suggested I send it in to be repaired at a cose of $163.50 Australian. Pleasant staff they have, but no help in solving what looks like a common problem of Canon cameras. I will have second thoughts purchasing Canon from here on in.
LCD screen black, no viewed image displayed.
Internal video out connection may be bad, try using the provided cable to connect to TV and disconnecting to see if it returns to normal.
FD-88, viewing LCD in daylight, too bright
You're not doing anything wrong. Sometimes it's just hard to see to LCD. You could try turning down the brightness, or turning off the backlight, but that doesn't work very well either. There are sun shields for sale. I have a FD-88 also, And so far I've been able to see the screen ok in sunlight. But It's winter in Minnesota so the sun is low in the sky, and I can normally shade the screen with my body. Hope this helps.
Top Pentax Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Rob Hill
Rob Hill
Are you a Pentax Camera Expert? Answer questions, earn points and help others
