Sharp TM-150 Cellular Phone Logo
Posted on Dec 03, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
MY SHARP TM 150 DISPLAYS HANDSET CODE ANY TIME I PUT IT ON, PLEASE I NEED A CODE TO UNLOCK IT
Anonymous
Level 2:
Sergeant:
  • Expert 165 Answers
  • Posted on Dec 03, 2010
Anonymous
Expert
Level 2:
Sergeant:
Answers
165
Questions
0
Helped
25862
Points
554
Push the reaset button around or under the battery. You might need a paper clip to reset it.
1helpful
Will a factory reset on an unlocked ATT sharp Fx cell phone lock it?
No.
Unlock usually means the phone is unlocked for different sim cards by different companies. For example, I have an ATTphone and I unlocked it for use on Tmobile network. Also, applies for taking your phone to another country to use their cellphone network providers.
Factory reset only changes the DATA of apps, user settings, phonecalls, messages, etc.
Unlock is not connected to that portion of control for factory reset.
2answers
My E63 has been blocked by the Optus network...how do i un block it
Your handset can become fully locked due to exceeding the number of attempts to enter the correct unlock code. The type of handset you have will determine what process to follow to see if the handset can be unlocked.If your handset appears with a Code Error or does not unlock with the first or second attempt, you will need to call Customer Service to confirm the code. Once the handset is fully locked it will require manually unlocking from Optus and your handset will need to be sent away.
1 Insert SIM
N.B. Can be unlocked with SIM removed from handset however there is a 5 second time limit 2 Power phone on 3 Type: #pw+15 digit code+1 (where '15 digit code' is the unlock code) 4 Press Hash (#) - SIM Restriction OFF will display on screen for one second
Troubleshooting:
  • If the unlock code is incorrect the phone will display the message 'Code Error'
  • If the user tries to unlock a phone which does not have SIM Lock activated the phone will display the message 'SIM was not restricted'
  • If the syntax (#pw+) is incorrect when entering the unlock code - nothing will happen.
1helpful
2answers
At&t lg prime gs390 free unlock codes
Please see below instructions in details on how to unlock code for LG phones, (i have included various model of LG for you to try)
Here are some unlock codes for AT&T LG phone available, menawhile , including the methods of entering the Unlock Code on your LG phones attached to them. Hope this is useful. AT&T cell phone Questions&Answetrs
Model : AT&T LG VU CU915 & CU920
1. Put a AT&T or Cingular SIM in the phone; it does not have to be an active SIM 2. Enter *#865625# then the 16 digit unlock code 3. Device should say: Network Lock Deactivated 4. Phone may automatically reboot and is now unlocked !
Model :AT&T LG C2000
Insert non-Cingular SIM card Power on the handset - phone will display "phone restricted" Select "Cancel" - phone will display "phone restriction code" Enter the SIM Unlock code. Select "OK" - the handset is now successfully unlocked
Model : LG TU720 - LG CU720 and all LG Shine SERIES
1) Power ON your phone with an accepted SIM card 2) Type *#865625#UNLOCK CODE 3) Press OK 4) Device is now unlocked
Model : LG CE110
1) Put a non AT&T or Cingular SIM in the phone; 2) The phone display: Invalid Smart Chip 3) Power on handset 4) Select "Cancel" - phone displays "phone restriction code" 5) Enter the unlock code (8 digit code*) 6) Select "OK'" - the handset is successfully unlocked
Model : LG CU400
1 - Insert non-Cingular SIM card" 2 - Power on the handset - Phone will display "Invalid SmartChip" 3 - Phone will display "Invalid SmartChip" 4 - Enter 159753#*# 5 - Enter the 8 digit SIM Unlock code 6 - Select "OK" 7 - The handset is now successfully unlocked
Model : LG CU500
1 - Insert non-Cingular SIM card" 2 - Power on the handset - Phone will display "Invalid SmartChip" (IF THE PHONE DOES NOT DISPLAY INVALID SMARTCHIP, PLEASE POWER OFF AND ON AGAIN) 3 - In Idle screen, enter 159753#*#. Phone will display "Enter NCK, Remaining 5 4 - Enter the 8 digit SIM Unlock code 5 - Select "OK" 6 - The handset is now successfully unlocked
How to Unlock LG CU515:
1-Insert non-Cingular SIM card" 2-Power on the handset - Phone will display "Invalid SmartChip". 3-Enter *#865625# then select option 1 and then again select 1 4-Enter the 16 digit SIM Unlock code 5-Device should say: Network Lock Deactivated 6-The handset is unlocked. 7-How to Enter Unlock Codes on CU575 (Trax) How to Enter Unlock Codes on LG F2250:
1-With allowed sim card in the start menu type: 2945#*3311#. 2-Handset shows saved, then return to startup screen 3-Press Menu key, choose Settings > Security > Sim Lock> Network > Deactivate, handset will now show 'Enter NCK' 4-Enter your unlock code and OK. How to Enter Unlock Codes on LG U8110:
1-With a not allowed sim card in your phone enter Pin code then validate, type: 277634#*# 2-Select 'Sim Unlock' menu # 3-Enter NCK code then validate 4-Your phone is now unlocked. How to Enter Unlock Codes on LG U8210:
1-With a not allowed sim card enter Pin code then validate, type: 277634#*# 2-Shows test menu 3-Choose sim test menu and type: 2945#*#, choose Sim Unlock menu 4-Handset shows 'Enter NCK' 5-Enter code, then hit OK. How to Enter Unlock Codes on LG U81xx:
1-To bring up the unlock menu on the phone with a SIM card, type 2945#*88110# 2-Enter the code 3-In case you need to reset the phone without a SIM card first, type 277634#*# or 47328545454#. If your cell phone is not listed, please follow instructions for LG C2000 above
If If instruction above does not help you i would strogly suggest to contact your Service Provider to provide some alternatives.
Thank you for using fixya
Please rate me and give testimonials if ever to continue my assistance
lg-phones
Sharp tm 150 phone entered handset code
Enter Default code 1234 or 0000 or call service Provider Help.
Nov 18, 2010 • Cell Phones
How -150? to unlock sharp TM
http://nds1.nokia.com/phones/files/guides/Nokia_3120_UG_en.pdf
Click on the above and read the page.
You can use this company or anyone you prefer
As it is a hard phone to unlock.
Hope i helped!
How to unlock a SHARP TM 150 cell phone
Use unlock code to unlock your mobile...Get the unlock code here theunlockspot.com and also get the unlock instruction in the same site...
2helpful
Unlock code nokla n95
Further to your communication with Vodafone regarding the unlocking of your Nokia handset, I have set out the following procedure and unlocking code:
1. With the Vodafone sim card inside the handset
2. Key #pw+129022718795152+1# (The p w and + symbols are found by keying the * key twice for the + symbol, three times for ‘p’ and four times for ‘w’)
3. The handset should then display “Sim restriction off” which means it is unlocked
NB. If the handset fails to unlock, then please do not attempt to enter any sequence more than twice, as you will risk permanently blocking your handset. "
Mar 20, 2009 • Cell Phones
Top Sharp Cell Phones Experts
NOEL
NOEL
ADMIN Andrew
ADMIN Andrew
Are you a Sharp Cell Phone Expert? Answer questions, earn points and help others
