Question about Prima C2012 TV
Need code for Prima tv remote - Prima C2012 TV
Posted by cclarabie on
    Top Expert:
  • Prima Master
  • 76,416 Answers
Hello
Four digit universal remote code for Prima are:-
1019 0165 0116 0167
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Code Search If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
OK.
Posted on Dec 03, 2010
4 Related Answers
Anonymous
  • 5 Answers
SOURCE: I need 3 digit code for my Prima tv to program bell express vu
Programming an Expressvu remote control can be frustrating. There are two basic ways of doing in it. The first one involves knowing both your TV brand name and also knowing the proper code to input in your remote. The second method is doing an automatic search. The following is a step by step procedure in how to program your dish network or Expressvu remote.
1)Make sure your TV and Satellite Receiver is ON.
2)Press and hold TV button until all lights on the side of it flashes. The TV button is the second button on the Top left hand side corner of the remote control.
3) Release that button, then press & release RED Button. You will notice TV button is stays on. If, it doesn't stay ON, you must repeat step 2 & 3. Otherwise, your batteries are low, you MUST change then.
4)Press and release the UP Arrow Key on the remote until TV turns off. Notice the UP arrow key button is the button below the volume keys (Stop button for VCR.)
5)Make sure you are aiming remote control to TV while pressing and releasing UP arrow key button. When you find the right code, the TV will turn OFF.
6) Immediately after, TV turns off, press # key.
Posted on Aug 23, 2010
Anonymous
  • 15 Answers
SOURCE: three-digit code for prima tv for universal control
If you can't find it under prima look under legend
If not read your manual and depending on the remote you have a option for the remote to find the code by itself
Just have to follow the instuction in the remote user's guide in the place that says "Brand not listed"
Good Luck
-John-
Posted on Dec 30, 2007
Anonymous
SOURCE: Prima TV codes for using other remote control
anyone know the manufacturers code for my prima tv remote? Model is cr27sb72
Posted on Nov 23, 2008
Anonymous
SOURCE: remote control code
Prima 4101 4138, 030,032,036,039,047,054,056,060,091,016,415
466,092,166,251,017,281
BIG SCREEN=166,019,035,154,451,037,068
Posted on Feb 24, 2010
I need codes Prima tv LCD Model L3217 for remote control
These are universal remote codes for Prima TV.
1019 0165 0116 0167
Jul 04, 2012 | Prima C2012 TV
I can't find a remote for my Prima TV model#XT-2799. Help!!
Universal remote codes for Prima TV are:
1019 0165 0116 0167
Just note these codes, and buy a universal remote control, which have these setup codes in its code list.
If your TV asks for a five digit code, buy one RCA RCR 311STN model remote control. Five digit codes for this remote control, with Prima tV are:
10761, 10783, 10815, 10817
Jun 13, 2012 | Prima CV2011 TV
Remote and Tv codes
Try the samsung code.
May 13, 2010 | Prima C2012 TV
I need a code for prima tv model XT2599SS
i need a remote that will work with my Prima tv
i purchased this couple years ago at future shop
i was informed they no longer carry this brand anymore
need a code to work universal remote
Jul 08, 2009 | Prima C2012 TV
The code to program my remote control for my tv Prima PH 42R6C''
I need to know the code to program a new universal remote tv for my PRIMA PH-42R6C. I don't find the code and i don't know what kinf remote i need for this tv.
The problem is i lose the remote
Thank's for your help
[email protected]
Mar 03, 2009 | Televison & Video
Can't get the remote to work
Try pressing the TV button on the Prima remote to make it work on the TV. It should work on the Prima Tv without new codes. Codes would be needed for your cable box.
Consider calling Prima at 866-447-7462 for the codes. They should have a website for the codes or email you the codes for free.
PS Please rate me if this helps.
Mar 30, 2008 | Televison & Video
I need codes PRIMA LCD modelo L3217
Jan 22, 2008 | Prima C2012 TV
Three-digit code for prima tv for universal control
Good Luck
-John-
Dec 29, 2007 | Televison & Video
Prima C2012 TV Logo
4,090 people viewed this question
Top Prima Televison & Video Experts
Todd Hill
Todd Hill
matt martin
matt martin
Are you a Prima Televison and Video Expert? Answer questions, earn points and help others
