SOURCE: My 37" LCD Philips TV has mind on its own.
your internal controller board is going bad in lcd
SOURCE: need help with TV calibration for philips
Try these,
Contrast: 53 Brightness: 56 Color: 45 Tint: 2 Sharpness: 2
Color temperature: Off
Dynamic contrast: Off
Digital Natural Motion: Off
DNR: Off
Color enhancement: Off
Active control: Off
SOURCE: Philips 52'' LCD HDTV. Has PC Input Issue.
My sony lcd works fantastic with my ATI video card; the 1080 looks superb.
I use the DVI to HDMI converter on the PC as well.
I wasn't able to get audio from the PC to the AV receiver via HDMI, but apparently my pc's internal audio chipset has a component that conflicts with ATI's HDMI Audio Out drivers. Still, I do get the Dolby Digital through digital PCM cable though, - but I digress.
I have read all your comments, and would have suggested you have a bad DVI/HDMI converter, except you said that it works in safe mode, which means that everything can work - the configuration just needs tweaking.
My first gut reaction is that you might review your ati catalyst settings, (and eventually your resolution settings and refresh rate. Unplug your connection from the computer to the TV. Load up your Catalyst Control Center, and get yourself out of the dumbed down options into 'Advanced View'. Plug your TV in. Does Catalyst detect it? Does your windows device manager detect it as a display? Catalyst ought to see it as an 'attached display currently disabled.' If so, drag it from the 'disabled' area to the 'Desktop 2' area. You will need to decide if you'll be running this display as a second screen (extended desktop) or a clone of your pc's monitor.
To spur Catalyst along with finding your TV, there is a Detect Display button under the representation of the two screens (labeled 1 & 2). Additionally, you may need to right click on the the #2 monitor icon and select 'Enable'.
I'd like to help solve your home theater issues, so let me know your results from these steps, and I will take your further down the troubleshooting path as required.
I hope that helps.
Start low and work your way up to where you'd like to be. (640x
One thing to consider is 'What is different when I load my windows in Safe mode?"
Is the PC loading at a
