SOURCE: i have a fujifilm finepix z30 says protected card.
The SD card has on a side a little switch. Turn in to the other position and it should work fine.
SOURCE: Everytime i turn on my fujifilm finepix camera it
this used to happen to me to try kinda julting it a little bit kinda hit it its the only thing that worked for me good luck!
SOURCE: Card Error
you should be able to re-format the card using the "tools" tab which is at the left-hand bottom side of the main menu. This should wipe out all images and any bad data that may have been stored by the memory card.
SOURCE: Hi my camera model is
Look at your memory card. SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
