Question about Mitutoyo 0 150mm X .02mm Dial Caliper
How do you rezero a 505-637 mitutoyo dial caliper
Jeff Bonvallet
    Scholar:
  • 41 Answers
Fully close the caliper. The pointer should be pointing about straight up or close to it. Losen the knurled screw which is located on the circumference near the bottom. Now grab the dial and turn until the zero lines up with the needle. Re-tighten the knurled screw.
Posted on Dec 03, 2010
Testimonial: "No"
How do I change the battery in a digimatic model # cd-6
In mitutoyo digital vernier battry inserted upper portion side by display you battry cover theire is an arrow mark downward release you will find battery in side remove it and put new one battery code Sr 44 you will from marketor in mall try it
Oct 17, 2012 | Mitutoyo Dial Calipers
The bezel clamp and knurled knob have dissapeared from my 6 inch dial caliper, where can I get a replacement.
longislandindicator.com is the only place i am aware of besides going back to the factory
Apr 27, 2011 | Mitutoyo Dial Calipers
Pointer is approximately 0.010" out
As far as I know there isn't a way to get them any better than .01 without sending them in for repair. you can try longislandindicator.com for repairs
Feb 13, 2011 | Mitutoyo Dial Calipers
The face on my dial calipers is turned 90 degrees to match up to 0. How do I adjust it to be correct and readabel?
There should be a small set screw you can loosen by hand and adjust the face of the dial to zero with the jaws closed....this is typical of most calipers...it allows you to zero the dial on a given thickness of material and only read variations based on that thickness.
Take care.
Dec 09, 2010 | Mitutoyo Dial Calipers
My caliper is .030 off of zero I don't know how this happened . How can I fix this problem
Just loosen the screw that clamps the dial in place, close the jaws, and turn the dial to zero. Then tighten the screw clamp
Sep 18, 2010 | Mitutoyo Dial Calipers
How to reset zero position reading on a mitutoyo 505 629 dial caliper?
unless they have changed them there is asrew like a watch winder on the dial it self ,undo it slightly and turn the dial to the desired position then retighten the screw
Nov 08, 2009 | Mitutoyo 505 677: Test & Measurement...
How do I change the battery in my Mitutoyo digital?
The battery compartment is on the front of the instrument. The cover is round and has some symbols that resemble arrows pointing down. Slide the round cover down to access the battery.
Nov 05, 2009 | Mitutoyo 500 506 10 Electronic Digital...
How to disassemble dial calipers
I wouln't do it, you will strip the rack & gears. But if you must, a 10 pound hammer would make short work of it.
Sep 11, 2009 | Mitutoyo Dial Calipers
Mitutoyo 0 150mm X .02mm  Dial Caliper Logo
1,209 people viewed this question
Top Mitutoyo Measuring Tools & Sensors Experts
Andrew Taylor
Andrew Taylor
Tom Chichester
Are you a Mitutoyo Measuring Tool and Sensor Expert? Answer questions, earn points and help others
