Question about Measuring Tools & Sensors
Does the Sperry DM-350A test for continuity? I can't seem to find a setting that works.
Posted by jed_haas on
Anonymous
    New Friend:
Yes. But you have to change the LEADS down below. One must connect into the Omega connection at the bottom (looks like an upside down horseshoe). And the meter setting is where the arrow (?) symbol is. Touch the two leads together and it should "zero out". Now you're ready to check continuity.
Posted on Dec 11, 2010
Testimonial: "That was helpful. Thanks."
How do I know if I have continuity on my Sperry dsa 500
Set the knob to the ~600V position. With the power on/connected, place one test lead on one side of the fuse and the other test lead on the other side of the fuse. Be careful not to touch anything with your hand or you will get shocked. If you read voltage the fuse is bad. If you don't read voltage the fuse is bad.
Alternately you could DIS-connect power remove the fuse and test the fuse for OHMs, which on your meter is the last icon with the ((((.
It will beep and/or read very low ohms <5.
Here's the manual -
Sperry Instruments DSA 500 Operating Instructions
Jan 02, 2018 | Whirlpool Dryers
Changed battery on Sperry DM-5300 and now it will not power up
Try it again, with a new, tested battery.
You likely installed a "dud" (or put it in backwards?)
Jan 23, 2015 | Televison & Video
Volt meter
If you've never used a volmeter,Google it.There is a lot of info for free.
Jun 13, 2012 | Televison & Video
Just tested gfci receptacle with sperry gfci outlet tester and got all three (red,yellow,yellow) lights. What does this mean??
Your tester is defective then. All 3 lights should not light up. The correct wiring would be 2 yellow, no red.
Mar 01, 2010 | Sperry Instruments HST401 Voltage...
Don't know how to use my Sperry outlet tester
http://www.sperryinstruments.com/documents/products/hst-401.pdf
Dec 15, 2009 | Sperry Instruments HST401 Voltage...
Checking batteries
I assume a "DM-350a" is some kind of a digital multimeter. I Googled and found it might be a "A.W. Sperry DM350A 5 Function 17 Range Digital Multimeter" and looking at the ranges available on that meter, you can't really thest the battery "under load" the only reasonable way to test small batteries. the DC current only goes up to 200 milli amperes. A "C" or "D" size flashlight battery puts out 1 to 4 amps depending on conditions. That's 5 to 20 times the current readable by that meter. The volts on one of those batteries is probably 1.6 volts to 1.3 volts etc. If you live in the United States, I'd say go to Radio Shack and spend $5 to $15 and buy a battery tester like "Enercell Analog 9-Range Battery Checker, $14.99, Model 22-156, catalog # 22-156"
Then you and anyone in your family can read the instructions and test 8 or 9 different type batteries. Battery types: 1.5V button-cells, "AAA"/"N"/"AA"/"C"/"D", 6V, 9V, 12V, 15V and 22.5V..
This is not supposed to be an advertizement, and I have no interest in RadioShack,... but it's supposed to be instructional.
Small price, Good instruction to anyone who can read, and if anyone forgets, they can re-read. Testing a lot of batteries in a sitting goes very fast with these.
Differently, with the sperry, or any voltmeter, you'd have to select a resistor small enough to draw the current, and large enough not to overheat or burn, connect it and measure the loaded voltage drop, compare the voltage and current of the loaded battery, and compare it to that of a new battery, and a battery you might consider too weak for your application.. Voltage equals amps times resistance, and power equals amps squared times resistance... Really, buy a battery tester.
Regards --- GooseBay_Camper
Sep 26, 2009 | Sperry Instruments HST401 Voltage...
I just brought a sperry dm-350A to test the switches on my dryer I thought they would come with instructions on how to use it but it didn't. Is there a place where I can go and learn what the symbols...
Just got mine from home depot. Stick the black wire into the COM port and the red wire in the V port on the right. The red wire is the positive and the black is the ground. Touch the red tip to the positive and the black one to a ground. Turn the dial clockwise to the right and you are measuring your voltage(i left it on 200).
Jul 11, 2009 | Measuring Tools & Sensors
Checking batteries AA D cel with a sperry DM 350A digital multimeter
dc .... no lower then the voltage range of the highest voltage of the battery.
Sep 06, 2008 | Measuring Tools & Sensors
Set does not turn on. Green lights continually blink.
you need the DM repair kit to rep[lace the bad capacitors on the DM power supply. You can get the V21/V19 DM repair kit at the following link which contains the replacement capacitors and the Cd with detailed instructions for the repair with clear instructions and pictures. heres the link.
http://servicemanuals.vstore.ca/
Jun 22, 2008 | Mitsubishi WS-55859 55" Rear Projection...
Measuring mA with a DMM
The most obvious solution to your problem is that you may have the meter simply connected backwards. To make life easy, Groovetubes sells a thing called a bias probe that makes biasing tube amps a breeze.
Dec 27, 2007 | KEF Audio Cresta 2 Speaker
Measuring Tools & Sensors Logo
9,159 people viewed this question
Top Measuring Tools & Sensors Experts
Marvin
Marvin
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
