HI markyague do you have the desktop manager loaded on yout computer. If you do the the software is you need to reload your applications onto your blackberry. You will need to backup the information as you reload the doftware if you do not. You will be in out of luck on the contacts and any other nformation. The bb desktop will help you save all your information from the phone. yES EVEN YOU BBMS. Hope this helps
I’m happy to help further over the phone at https://www.6ya.com/expert/ronald_e152e07e272e4f27
//z44/sss
SOURCE: need to reload software 513 blackberry
the Application error 513, reset message says that the device OS is toasted and needs to be rebuilt. In order to do this, you need to have Blackberry Desktop manager on your computer, your data cable, and a download for your device software. Either from blackberry or your carrier. The easiest method is to download and install the device software. Once it's installed, launch desktop manager and plug in the phone. If the phone is detected, you will be prompted to update. Follow the prompts. If not, you will have to do it the hard way. open command prompt (start>run>cmd) and goto C:\program files\common files\Research in Motion\Apploader Then choose Loader /NOJVM That's going to rebuild the blackberry.
SOURCE: how do i reload software 513 for my blackberry storm.
What you need to try to do is reinstall the blackberry OS (operating system) on your device.
Assuming you have verizon
First install Blackberry desktop manager it should be in the CD that came with the phone.
If you can't find it download it
https://www.blackberry.com/Downloads/contactFormPreload.do?code=A8BAA56554F96369AB93E4F3BB068C22&dl=5E695511C1F9656B8E3E63DAB060F469
Then download the OS software for your phone http://vzw.smithmicro.com/blackberry/download.aspx?ct=personal"
Install it
Connect your phone to your computer and start Desktop manager
Click on application loader, on update software click start, click ok on USB pin selection.
when you get to the device backup and restore options, click settings
and make sure backup options box is unchecked and device data boxes are
both checked, click ok, click next, skip the email signup stuffs,and
finish.
After the software is installed the phone should boot back up
SOURCE: Reload software 513 for blackberry storm
I'm not too sure if all your data will still be there. But you can fix this yourself. You should be able to reload the device software with the Blackberry Manager.
