Apple MacBook Mac Notebook Logo
Posted on Dec 03, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a macbook from 2006. the software has been upgraded to leopard. when i turn it on the apple loading screen appears stays for around a mintue than shuts itself off.
JDTec
Level 3:
  • Apple Master 4,338 Answers
  • Posted on Dec 03, 2010
JDTec
Apple Master
Level 3:
Answers
4338
Questions
0
Helped
2127857
Points
14653
Insert your Utility disk that came with Leopard. Then run a disk repair.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
CAN I UPGRADE TO MAVERICKS ON APPLE MACBOOK 2007 LAPTOP
Yes anything with a core 2 duo should work. The only requirement that I'm aware of is 64bit processor and Core 2 Duo is just that. Now if it was a Core Duo (or Core Solo) this would not work.
I’m happy to help further over the phone at https://www.6ya.com/expert/matt_7e951e081251ffbc
1helpful
CAN I UPGRADE FROM OS X LEOPARD 10.5 TO MAVERICKS
Nope, yo can upgrade to osx lion (10.7 max),
Apple says you'll need a better graphics card if you want to use mavericks.
Your macbook has a Intel GMA x3100 which is unsupported.
Try osx lion if you hace 4gb of RAM. It's cool :)
Cheerio :)
I have Mac OS X 10.5.8 need to upgrade to 10.6
The PowerBook G4 line was the last generation of the PowerBook series, and was succeeded by the Intel-powered MacBook Pro line in the first half of 2006. The latest version of OS X any PowerBook G4 can run is Mac OS X Leopard, released in 2007.[
Your computer is too old.
I am running OS X 10.4.11 and would like to upgrade my operating system?
Please provide more information.
To what would you like to upgrade it?
Since OSX Mavericks was just announced, I'm going to assume that's what you're wanting to upgrade to.
Not all Macs can run Mavericks.
Mavericks Capable Macs
Mavericks, like its predecessor Mountain Lion, requires one of the following Macs with at least 2 GB of RAM and 8 GB of available hard drive space:
  • iMac (Mid 2007 or newer)
  • MacBook (Late 2008 Aluminum, or Early 2009 or newer)
  • MacBook Air (Late 2008 or newer)
  • MacBook Pro (Mid/Late 2007 or newer)
  • Mac mini (Early 2009 or newer)
  • Mac Pro (Early 2008 or newer)
  • Xserve (Early 2009)
If your Mac isn't one of the ones listed above, you won't be able to upgrade.
If you have an iMac, MacBook, MacBook Pro, or Mac mini model that was originally released in Early/Mid 2006, the latest version of Mac OS X your system supports is Snow Leopard.
http://store.apple.com/us/product/MC573/mac-os-x-106-snow-leopard
3answers
2006 Macbook Pro replacement screen problems
You have a bad driver. Reinstall your screen driver or clear your P ram by holding the letters P and R and the control button when you boot your laptop. Hold them until it chimes and reboots.
Have Mac OSX Snow Leopard v 10.5.8 need to upgrade to 10.6
You'll need to purchase the software via Apple Store App. You should be able to do a inplace update or you can do a fresh install as well.
Macbook black will not start beyond the initial 'bong'. Blue screen followed by endless spinning gear. PRAM, SMV reset, no go. Safe mode can't complete. With battery or on power adapter same result....
Hello yang2699tlk,
Try this instead of using your Leopard Disc.
  1. Immediately after the "bong" press and hold down "Command + S".
  2. Wait for blinking cursor and then type fsck -y (exactly like that).
  3. If you receive an "Appears to be OK" then type reboot and hit the return key.
  4. If you receive a "Disk has been modified" then repeat the fsck -y command until you get an "Appears to be OK" then type reboot and hit the return key.
This set of commands entered in "Single User Mode" will repair your disk. If this does not work remove the hard drive, plug it into another Mac and transfer your data to a different computer. Then install a new hard drive and reinstall Mac OS X.
Hope this helps, don't forget to vote. Thanks.
Can I upgrade my Macbook Pro to more than 4GB ram?
4GB is the MAX but only 3GB is utilized.
What Os are you running. Tiger Leopard Snow Leopard?
MacBook Pro 15'' RAM Problems
The earliest MacBook (Pro) models have a limit of 2 GB. To check the specific model, in the Apple menu select about this Mac. Then press more info... . Look at the line like "Model Identifier: MacBook5,2" for my white early 2009 MacBook. If the numbers are 1,1 then for sure you have the oldest model and are memory limited to 2 GB, as the sum of both cards.
That's just like my wife's, it was a Core Duo and not the current Core 2 Duo. Works fine. I was ready to up its memory but read about this in the Apple Support Forum. It came originally with 1 stick of 512 MB, IIRC. I upgraded it to 2x1 GB for a lot more than the 2x2 GB in the newer. BTW some of the Macs between these only take 3 GB but will work with 2x2 GB just throwing 1 GB away. -Ken
Top Apple Computers & Internet Experts
Paul Carew
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
