Gravity holds the motor in place and the weight of the motor keeps the belt taut. If your belt is rubbing because the motor is too low, your belt may be too long. Have you replaced it recently? Also check that the bolts holding the motor to the motor mounting plate are tight. If the motor is shifting in use, that's not good...
Assuming this is a Delta 36-444, the manual is
here. See pages 10-14 for motor setup instructions to make sure yours is setup properly.
Safety note: as with any power tool, unplug it before you start working on it.
If you need more help, please ask. If this answer was useful, give it a thumbs up.
