SOURCE: eddie bauer rear/front facing manual
Dorel Juvenile Group is the company you contact for any thing dealing with eddie bauer
Misplacing product instruction manuals can be such a headache. That’s
why a downloadable version of many of our instruction manuals are
available right here online. Simply fill out the form below and click
Search!
link: http://eddiebauer.djgusa.com/instructions/
call for help: (800) 544-1108
(7 a.m. to 6 p.m. EST Monday through Thursday,
and 7 a.m. to 4:30 p.m. EST on Fridays)
SOURCE: eddie bauer car seat 22740 manual
Go to http://eddiebauer.djgusa.com/instructions/ and search for your model number.
SOURCE: how to install infant car seat
The two clips are both for the LATCH system - they're not top tethers (which go to the back of the seat for forward facing seats only).
You need to choose EITHER the LATCH installation OR the seatbelt installation - doing both together can put too much stress on the belt path of the seat, causing the plastic to weaken.
If your car has the LATCH system, there will be two metal U-shaped anchors in the seat, where the seat back and the bottom of the seat meet. Some cars only have them for the side seats, not the middle, so check your car's owner's manual - if you don't have them specifically for the center seat, you'll have to either install with the seatbelt or put it in a side seat to use the LATCH - don't try using one anchor from each side, as they won't be the proper distance apart.
If you'd prefer to use the seatbelt to install, kneel with all of your weight in the seat to tighten the seatbelt. It's tight enough when it can't move more than 1 inch from side to side if you grab it at the belt path and pull it back and forth. You probably will still be able to pull the TOP of the infant seat back towards the back of the seat of the car - that's not a problem - it helps the seat to cradle the baby through an accident.
You need to have an owner's manual, though - to request a copy, contact their customer service at [email protected] or call them at 1-800-544-1108.
SOURCE: How do I convert my car seat to a boster seat
Remove the large bar holding the bottom plate. One side will have a plastic retainer which you just move to the side and pull the barr all the way out from that side. There is a rear leg that you can pull down and back which will make the seat sit more upright. Remove the strap (it is one solid strap) and be sure to save all the parts if you plan on giving it to a needy family when your child outgrows it. The center clip is easy to remove, turn the seat upside down and find the metal retainer and pull it up, turn 90 degrees and feed it through the hole and pull on the other side. Now you should have a strap/clip free seat that will be a "seatbelt positioning booster seat".
SOURCE: Eddie Bauer car seat seat belt replacements??
Q: Where can I purchase replacement parts for my product?
A: Contact our Consumer Relations Department at 1-800-544-1108 Monday – Thursday from 7 a.m. - 6 p.m. and Friday from 7 a.m. – 4:30 p.m. EST. The model number and manufacture date of the product are required for replacement parts.
24 hours a day 7 days a week
1-800-426-8020
BY MAIL
Eddie Bauer Customer Service
P.O. Box 7001
Groveport, OH 43125
For Hearing Impaired Service:
TTY 1-800-462-6757
M-F 7-3:30 EST
To e-mail Eddie Bauer: http://www.eddiebauer.com/custserv/ask_eddie_email.jsp?sectionId=24448
